Wiring Off Of A Light- Switch To Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 02:12 PM   #16
Rewards Points: 150
If you have access to the wiring, you need to replace the 14/2 going to the switch from the light with 14/3. You would connect your white to your neutrals, the power to the red and black to the light. In the switch box, you would connect your red to the right side of the switch, your black to the top left and neutral to the bottom left and then connect your grounds. That's how you would install a switch/outlet combo
romex1220 is offline   Reply With Quote
Old 07-30-2013, 02:19 PM   #17
Licensed electrician
Rewards Points: 1,774
Top, bottom, left and right are meaningless as there can be differences between brands and installed position.
jbfan (07-30-2013)
Old 07-30-2013, 04:35 PM   #18
Rewards Points: 150
I can see how someone would be confused by that. I was looking at one of my switch combos that is wired in the same configuration and just going off of that. Sorry about that
Old 08-04-2013, 12:06 AM   #19
Brian58Fraga's Avatar
Here we go......... Take the white wire (switch leg) currently wired to the light off the light wire to the neutral feed wire in that box then go ahead and wire your receptacle up, then get some of those battery push lights!
Brian58Fraga is offline   Reply With Quote
Old 08-04-2013, 06:29 AM   #20
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by Sirscrub124 View Post
any suggestions. i need an outlet in this closet for a natural gas alarm. Would a switch/ out let combo work. Thanks for the help
hmmmm .....
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Light controlled by switch, outlet always on, power at light...is this the way? pureevil Electrical 6 11-07-2010 05:32 PM
Wiring an outlet to go with switch KATWALK Electrical 11 11-05-2010 03:52 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 06:25 PM
