Wiring Non-polarized Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2012, 06:09 PM   #1
Wiring non-polarized plug
Can anyone tell me how to wire this plug correctly?
http://www.leviton.com/OA_HTML/Produ...minisite=10251
(It is a Leviton non-polarized plug).
I have a hot (black) and neutral (white) wire. I took the plug apart, and cannot tell what to do. There is no blade wider than the other. Both receptacles are brass (not silver to distinguish neutral)
copacetic1 is offline   Reply With Quote
Old 10-08-2012, 07:17 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,608
If it's a non polarised plug,
then it doesn't matter which wire
goes to which pin !
dmxtothemax is offline   Reply With Quote
Old 10-08-2012, 08:26 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
A polarized plug can be found here
or at most hardwares.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 10-08-2012, 08:32 PM   #4
Thanks for the responses. Is a non-polarized unsafe in any way? Should I use polarized?
Old 10-08-2012, 10:31 PM   #5
Most non polarized appliances are double insulated ,
That means they have no earth.
In which case yes it is safe.
As they have to pass certain minimum standards
to be approved as double insulated.
So in most cases a non polarized plug on an approved appliance is safe !
Old 10-09-2012, 05:38 PM   #6
Rewards Points: 266
Is this a replacement plug? If so, was the original plug polarized? If so, you should replace it with a polarized plug and pay attention to the the color of the wires in the cord. If not, go nuts with the plug you have.
ionized is offline   Reply With Quote
Wiring Lights To A Plug TssCman123 Electrical 60 07-28-2012 04:00 AM
wiring switch to gfci plug wendl Electrical 5 04-05-2010 09:02 PM
wiring for welder plug Bullmoose Electrical 4 12-02-2006 12:27 PM
wiring a usa plug Unregistered Electrical 5 02-28-2004 11:57 AM
