Wiring NM In Conduit For Basement Walls - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2013, 10:05 AM   #1
Rewards Points: 186
Wiring NM in Conduit for basement walls
I'm redoing our 1954 houses' wiring and I just passed the rough in inspection, and 12 new circuits for the main floor are now live, but our somewhat unfinished basement needs a few replacement circuits so I can replace the boiler. The basement on some walls is 3/4" pine painted panels (shimmed off 3/4"), and the original steel BX was run hither and there, spliced randomly, and where they needed an outlet (for washer and gas dryer) it was run with steel conduit down the wall and then attached with concrete anchors for the metal box. I need to replace these few outlets and I'm rewiring everything with 12 gauge NM (except for smokes which are 14-3), on a bare wall without paneling (paneling is only shimmed out 3/4") do I just follow the same pattern of running the NM in the ceiling (through joists), and then down the wall with sch-40 (or 80? whatever the grey plastic is)? I'm comfortable with the plastic piping as I used to do a lot of low voltage outdoor wiring, and I assume this procedure is similar, but I've never bent steel piping for running NM or BX. Thanks!
Ocelaris is offline   Reply With Quote
Old 03-15-2013, 02:11 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Ocelaris View Post
<sniiiiiiiiiiip!> I'm rewiring everything with 12 gauge NM...
do I just follow the same pattern of running the NM in the ceiling (through joists), and then down the wall with...
surface mounted emt or pvc to the surface mounted device boxes.
Sure. EXCEPT that you really shouldn't put NM inside conduit.
Buy the clamp adapter fittings for the other end of the conduit...
then strip the insulation for the wire going down to the devices.
Old 03-15-2013, 02:34 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 530
Why??
The Following User Says Thank You to jbfan For This Useful Post:
stickboy1375 (03-15-2013)
Old 03-15-2013, 03:10 PM   #4
Rewards Points: 186
what would the purpose/benefit be of using EMT vs. Plastic. i.e. are there requirements for metal in some cases?
When can you strip the sheathing off Romex and use them in conduit?
For outside do you have to use UM cable in conduit or do you use THHN?
The some rooms don't have stud walls everywhere, and they need outlets, so coming out of the ceiling I assume I put a box, and then attach the EMT down the wall to a metal box.
Thanks!
Old 03-15-2013, 04:35 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Personally, just nail a 2x4 to the wall and staple the NM directly to it. OR staple it directly to the 3/4" paneling, NM is legal to run exposed, unless you find yourself having an axe wielding contest in your basement....
Old 03-15-2013, 04:43 PM   #6
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Not here. Any NM below the joist level of a basement must be protected. I thought that was universal?
(P.S. I am outside of the crazy Chicago electrical rules)
hyunelan2 is offline   Reply With Quote
Old 03-15-2013, 04:44 PM   #7
E2 Electrician
No, it's not universal, and if you don't have an amendment, someone is just having a power trip of a requirement.
Best flxible drill bit setup to go up/down walls for wiring? Grayguy Electrical 5 02-21-2013 07:08 AM
best flxible drill bit setup to go up/down walls for wiring? Grayguy Tools 0 02-18-2013 02:58 PM
Conduit questions in shed wiring TheCowGod Electrical 28 03-18-2012 01:42 PM
Wiring NEMA 6-15 with EMT conduit Richo Electrical 8 01-20-2011 08:56 PM
Conduit tubes for Structure Wiring Codes genner Electrical 7 05-29-2009 02:39 PM
