Wiring For New Washer And Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 12:39 PM   #1
Wiring for new washer and dryer
Had an old washer/dryer combo. Ran off of single 220v plug and line. Bought new washer and dryer.
Dryer takes 220v. Washer takes 110v.
I'm going to be doing a major renovation in about 2 months (rewiring everything) but can't wait that long for clean clothes. Can I piggyback a 110v out of the 220v circuit for the short-term or should I run an extension cord with the 110v from another room (probably living room)?
Otherwise I can cut holes in the ceiling to run a new line back to the breaker but that's a lot more effort for a 2 month solution.
brownmoose is offline   Reply With Quote
Old 08-27-2012, 12:57 PM   #2
Rewards Points: 2,516
SO you want to splice into one of the hot legs for the dryer outlet and the neutral of the dryer outlet and connect new wire/cable to each to run to a 110V duplex outlet? Can't you use an extension cord to a nearby existing outlet for the time being for the washer??
hammerlane is offline   Reply With Quote
Old 08-27-2012, 01:36 PM   #3
My concern is that the nearby circuits are:
Living room (only a 15 amp circuit with 14 gauge wiring)
Kitchen (already at capacity when I turn the toaster oven on).
Could try to run off of the circuit for the garbage disposal by changing switch to a switch and outlet combo but that would be pretty interesting wire run. That's why I've been thinking that tapping into the 220v would be a better solution. But it may just be that I should create a short-circuit off the box and just run an exposed extension cord from that.
Old 08-27-2012, 02:45 PM   #4
Well you cannot to splice into one of the hot legs for the dryer outlet and the neutral of the dryer outlet and connect new wire/cable to each to run to a 110V duplex outlet?
Im sure there would be an issue with over-current protection. You'd have 12AWG wire protected by a 30A breaker. A no no
Old 08-27-2012, 02:50 PM   #5
Rewards Points: 6,652
Also, you cannot run the appliance off of the extension cord. The wash machine requires a dedicated GFCI protected outlet, the dryer can be grandfathered on the 3 wire 240vac that is already there.
Looks like you need to get busy and pull some wire.
Old 08-27-2012, 03:02 PM   #6
Licensed electrician
Rewards Points: 1,474
The washer would only require GFI protection if within 6' of a laundry tub.
Speedy Petey (08-27-2012)
Old 08-27-2012, 03:35 PM   #7
Bombastic Idiot
notmrjohn's Avatar
Use one leg of the 220, remembering that is TEMPORARY. Do NOT use an extension cord in any case.
notmrjohn is offline   Reply With Quote
Old 08-27-2012, 03:48 PM   #8
Electrical Contractor
kbsparky's Avatar
Bad advice. Using a nice heavy-duty extension cord is MUCH SAFER than what you have posted.
-KB
The Following 3 Users Say Thank You to kbsparky For This Useful Post:
gregzoll (08-27-2012), jbfan (08-27-2012), Speedy Petey (08-27-2012)
Old 08-27-2012, 03:49 PM   #9
Using 1 leg of the 220 for what you want to do is more dangerous than a heavy duty extension cord to a receptacle that has a proper overcurrent device.
Regarding the load capacity of the breaker and wiring that runs to the dryer. If one or both is undersized or oversized, you're walking into trouble if you try to use it.
The Following User Says Thank You to hammerlane For This Useful Post:
Old 08-27-2012, 03:50 PM   #10
kbsparky...you beat me to it by one minute on the last posts.
Old 08-27-2012, 04:02 PM   #11
Thank you all for your advise.
So I think this is what I'm going to do.
Add a 10-15 amp GFI breaker to my box.
Connect 12AWG to breaker and run it outside the wall, in the corner along the ceiling to the laundry room. I'll then connect to a box and a GFI receptacle. I'll use that to power washer. Basically stringing cable but not snaking through walls to save time and because it is temporary.
I guess I should also put the cable in grey conduit if exposed too. Really wish this was as simple as "take out the old washer and put in the new one."
Thanks again for the advise.
Old 08-27-2012, 04:06 PM   #12
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
A washing machine draws nothing, just run it off an extension cord for the little time you need... gezz... The advice on here just pains me sometimes.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 08-27-2012, 04:29 PM   #13
Bombastic Idiot
notmrjohn's Avatar
I stand chagrined.
Old 08-27-2012, 04:48 PM   #14
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I have nothing to add. My friends here took care of this topic nicely.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 08-27-2012, 05:15 PM   #15
So I think this is what I'm going to do. Connect 12AWG to breaker and run it outside the wall, in the corner along the ceiling to the laundry room.... Basically stringing cable but not snaking through walls to save time and because it is temporary.
Whats safer stringing cable along the wall to a temp box and receptacle or using an extension cord to an existing outlet TEMPORARILY???
It is your choice. The people have spoken.
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 02:41 AM
washer plugs into dryer, but amps on plugs don't match nmliz Electrical 22 10-19-2011 05:39 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
