Wiring A New Track Pendant Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2010, 09:16 AM   #1
Wiring a new track pendant light fixture
I'm installing a new pendant track lighting fixture in to an unused electrical box in the ceiling with an unused switch. In the box, there's 1 red, 2 black, and 2 white wires capped seperately by color. There's also a bare copper wire attached to the green screw for ground.
On the light fixture however, there's a black, white, and green/yellow wire (x 3 since there are 3 lights). Which colors from the fixture do I attach to the red/black/white wires in the box? And does the green/yellow wires attach to the green screw along with the bare copper wire that's already there?
achettiar is offline   Reply With Quote
Old 03-29-2010, 01:26 PM   #2
Master Electrician
Well if the elctrician that wired it did his job right then the the white should go to the whites in teh box( carefull with this though as some guys will use the the whites as a return from the switch and not mark them hot). Most likely i would think that the red is probably your switch leg. You'll have to test it and see if it comes on and off with the switch. black goes to switch leg white to white and the yellow green wire goes to ground.
andrew79 is offline   Reply With Quote
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Track Light Installation NightOfDiscovery Electrical 6 12-13-2009 09:22 AM
Wiring of bare copper wire in a light fixture Fleet_Foxes Electrical 5 07-16-2009 08:44 PM
I can feel buzzing or "charged" air around a light fixture? jabrockson Electrical 10 03-26-2009 08:20 PM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 09:46 AM
