Wiring New Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 09:51 PM   #1
Wiring new Thermostat
Hi,
I want to change my old round dial thermostats out for new digital, programmable units.
My house was built in the early 1900s and is all knob and tube wiring to a fuse box.
My question is, can I simply attach the new unit to whatever wires are connected to the old one?
Also, wondering specifically if there is a digital model that can "talk to" a mate on another floor.
I'll be renting the upstairs of my house, but will be sharing the single furnace and want to have control of the heat.
Thank you kindly.
Ben
wombosi is offline   Reply With Quote
Old 10-22-2008, 10:20 PM   #2
Rewards Points: 2,350
Originally Posted by schmolze View Post
Hi,
Thank you kindly.
Ben
The old thermostat should have letters near the terminals where the wires are connected. Note which wire goes to what terminal and simply reconnect to the corresponding terminal in the new thermostat. Most T-stats I've seen are marked with the same letters, with a few exceptions.
As for the remote unit, check out www.honeywell.com They have a line of wireless T-stats, but they are a little pricey.
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 03:11 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Thermostat Wiring Problem crazy woman HVAC 2 08-15-2006 10:22 AM
