Wiring A New Outlet Advice - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2008, 01:07 PM   #1
Rewards Points: 652
Wiring a new outlet advice
I am adding a new outdoor outlet on my house. I am planning on wiring from an existing interior outlet. Upon removing the interior outlet I notice that there are two white wires(one each) on the non copper screws and two black wires(one each) on the copper screws on the sides of the outlet. When I have added extra outlets in the past, I have always had one set of the outlet screws open and I have just wired accordingly. Since all of the wires are being used, can I just pigtail the wires and go from there? For my own purposes, why might the wires have two white on one side of the outlet and two on the other? Isn't it normally one on each side? Thanks!
kennykenny is offline   Reply With Quote
Old 08-25-2008, 01:32 PM   #2
When is fishing season?
CowboyAndy's Avatar
Yes, you will need to pigtail.
The reason there are 4 wires (2 bl and 2 w) is 1 set is for the incoming power, and 2 feed another device down the line.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 08-25-2008, 01:32 PM   #3
Licensed electrician
Rewards Points: 996
The receptacles with 2 wires on each side are middle of a run. Power comes inon one cable and continues out to other parts of the circuit on the other cable.
Using a pigtail is the proper method to continue the wiring.
Note that bathroom, laundry and kitchen/dining receptacle circuits cannot be extended for exterior use.
Old 08-25-2008, 01:42 PM   #4
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Typical installation would have all of the hots (blacks) wire nutted together with a single wire "pigtail" also under the wire nut to hook up to the recep. Same on the neutrals (whites) and the grounds (bare).
Done this way if you lose a recep you don't lose the rest of the circuit.
comp1911 is offline   Reply With Quote
Old 08-25-2008, 01:57 PM   #5
Rewards Points: 652
JimPort---why is it that bathroom, laundry,kitchen/dining receptacle circuits cannot be extended for exterior use? That is what I was hoping to do. The receptacle is in the dining area below a window with nothing plugged into it and never used. Is it a code or safety thing?
Old 08-25-2008, 02:18 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
It is a code violation.
jbfan is online now   Reply With Quote
Old 08-25-2008, 06:32 PM   #7
Reference??
220/221 is offline   Reply With Quote
Old 08-25-2008, 08:53 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by 220/221 View Post
Reference??
Sml Appl (Kitch/Dining) 210.11(C)(1) which refers to 210.52(B). [No other outlets 210.52(B)(2)]
Laundry 210.11(C)(2)
Bath 210.11(C)(3)
Old 08-26-2008, 09:20 AM   #9
CowboyAndy's Avatar
BTW, it is not REQUIRED to pigtail...
just sayin...
Basiclly, the code says that those areas (kitchen, bath and laundry) are required to have certain circuits, and that they CANNOT serve other areas unless specified, such as a bathroom can supply another bathroom, or SABC in a kitchen can supply the dining rooom.
MY HOUSE OWNS ME!
Old 08-26-2008, 11:04 AM   #10
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
just sayin...
Did I say it's required?
I said it's a typical installation method.
Old 08-26-2008, 12:07 PM   #11
You are required to pigtail the grounded wire (white) on a multi-wire branch circuit.
hpp58 is offline   Reply With Quote
Old 08-26-2008, 12:17 PM   #12
For the outdoor outlet, I will assume that a GFCI is going to be used.
As for the bathroom/kitchen issue, I was considering extending an already GFCI protected circuit in the basement bathroom to a new outlet outside, but decided against it.
My thinking wasn't code, but that I wouldn't want someone in the br to be left in the dark (I know, lights aren't supposed to be on the GFCI anyway, but this is going to be rewired soon) if my electric lawnmower causes the breaker to trip.
I wired to another GFCI, also located in the basement, but not in the bathroom.
At the same time, I added a new outlet in the basement on the GFCI protected circuit.
FW
fw2007 is offline   Reply With Quote
Old 08-27-2008, 06:25 AM   #13
CowboyAndy's Avatar
Maybe in MN...
There is nothing against lights being GFI.
I've never understood the thinking about being left in the dark when a GFI trips. I mean really, most bathrooms Ive ever been in are like 3 steps to the door! Oh well...
MY HOUSE OWNS ME!
Old 08-27-2008, 08:33 AM   #14
Rewards Points: 996
What if you were sitting there and the GFI tripped leaving the lights out? How would you know if you had finished all the paperwork?
Kind of like using motion sensor switching that can't see you in a bathroom with stalls. Stand up and wave your arms wildly and hope for the best or praying for someone to come in so the lights go back on.
Old 08-27-2008, 09:38 AM   #15
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Maybe in MN...
It is in my house.
wiring outlet boxes, steel or plastic? DangerMouse Electrical 17 07-20-2008 01:05 PM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 03:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 09:10 PM
Wiring an outlet in the garden wackerjr Electrical 8 05-28-2006 09:18 AM
