Wiring New Outdoor Outlet Off Exisint Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2009, 08:18 PM   #1
Rewards Points: 156
wiring new outdoor outlet off exisint outlet
I want to install an outlet on the outside on my garage off of one that is existing on the interior of my garage.
I bought the proper outside outlet box and just want to know if I just pigtail the wires off of the existing outlet...if that is allowed or not.
Also would I pigtail the wires and then from the pigtail of wires go to each outlet from the pigtail....OR would I wire off of the electrical existing receptical?
Thansk!
hellothere123 is offline   Reply With Quote
Old 07-09-2009, 08:47 PM   #2
Open up another recep and see how it's done.
I generally do whatever is easiest.
As long as the connections are good and tight it doesn't really matter if you pigatail off the wiring or attach to the recep terminals.
You will have to pigtail the ground wire though.
220/221 is offline   Reply With Quote
Old 07-10-2009, 10:44 AM   #3
BIGRED
Rewards Points: 252
Also if you do not already have a gfci on the circuit for the outlet inside the garage (which you should consider) you will definitely need one for outside. You can spend 20-30 dollars on a breaker for the circuit in your breaker box or 10 dollars on a gfci for the outlet inside and follow the directions to connect the old recepticle on the outside to the new gfci recepticle on the inside. The first time you grab a wet cord outside and plug it in you will appreciate the extra work.
Grampa Bud is offline   Reply With Quote
Wiring a new outlet advice kennykenny Electrical 19 08-29-2008 11:54 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 03:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Troubleshooting bedroom outlet wiring? Operator4819 Electrical 15 04-01-2007 09:10 PM
Wiring an outlet in the garden wackerjr Electrical 8 05-28-2006 09:18 AM
