Wiring A New Living Room Addition - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 04:45 PM   #1
Rewards Points: 156
Wiring a new living room addition
Hey guys and gals. I am working on building a basement renovation for a buddy of mine and we are putting in 6 recessed lights. I think I will run that circuit on a straight 15 amp circuit. We are installing a fireplace in the room as well and the fireplace will have an electronic ignition switch and a rotary dimmer switch for the blower motor. How do I wire that up to the lights using the lights as the main power supply for the other two switches. I am then going to run 8 electrical outlets on the walls for outlets and such.
Main question--should I use the outlets as my power supply for the fireplace and blower or the lights? I am using 14/2 or 14/3 where needed on the lights and probably 14/2 on the outlets.
Hopefully this makes some sense
Here is a sketch up of the room.
ryan5068 is offline   Reply With Quote
Old 06-24-2011, 05:43 PM   #2
Lic Elect/Inspector/CPO
Depends on amperage of firplace motor. It might be best on the lighting circuit, since this would probabaly have the lowest amp draw. Tv, cable, surround sound etc if not all lreadythough about could be added to the outlet circuit in the future. These circuits will have to be arch fault protected, so it would be better to use 14-2 for home runs.
NJMarine is offline   Reply With Quote
Old 06-24-2011, 07:50 PM   #3
Electrician
Rewards Points: 794
If it is an electric fireplace you would need a dedicated circuit for because those things are usually a pretty high current item.
darren is offline   Reply With Quote
Old 06-25-2011, 05:09 PM   #4
Rewards Points: 156
No its a gas fireplace. Thanks
Living room arrangement challenge... r3yrey Interior Decorating 5 05-16-2011 01:22 AM
Need Help with Wall Color in Living Room MrBill_DIY Interior Decorating 4 07-27-2010 07:11 PM
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 09:19 AM
Smoke detector - Living room with FP and fan ><(((jan(((D> Safety 42 12-28-2007 08:59 AM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
