Wiring New Lights In Garage Question - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 02:20 PM   #31
Rewards Points: 97
Originally Posted by a7ecorsair View Post
You will have to figure out where the other end is for the cables that terminate in the two fixture boxes. The way you have it sketched just doesn't make sense and I can't see how it could work. It is hard to come up with a plan when we don't know for sure where the cables originate and terminate.
You should have a three wire cable between the two three way switches. Do you see this? How many cables do you see inside the switch boxes?
The round junction box you show on the left side of the drawing, how many cables for sure go to this box?
Both switches have 3 wires and no ground. The round junction just connects 2 blacks 2 whites and 2 grounds. Almost like they ran out of wire and just adding on.
Tyus4 is offline   Reply With Quote
Old 02-11-2011, 05:27 PM   #32
joed's Avatar
Rewards Points: 13,368
I ask again.
Originally Posted by joed View Post
Tell us all the wire connections inside the boxes.
Old 02-11-2011, 05:59 PM   #33
Rewards Points: 97
I ask again.
Is this what you want?
Old 02-11-2011, 06:37 PM   #34
I=E/R
a7ecorsair's Avatar
OK, one more piece to the puzzle.
Now, look at the screws on the three way switches ignoring the ground screw. Is one screw a different color than the other two screws or is there some reference printed in the case calling one a common?
a7ecorsair is offline   Reply With Quote
Old 02-11-2011, 07:00 PM   #35
Rewards Points: 97
I replaced switch #1 with a new one ( thinking this maybe a problem) and yes one screw is a different color than the rest. Switch #2 has all the same color screws
Old 02-11-2011, 07:18 PM   #36
joed's Avatar
It's a start. We need to figure out how the lights are connected to the switches. What about the junction boxes where the fixture cables are connected. Tell us how all the wires are connected in them. We also need to which screw connection is the common. That screw will be a different colour than the other two, usually black.
Old 02-11-2011, 07:30 PM   #37
Rewards Points: 97
In switch box #1 the black screw is on the red wire.
Switch box #2 has all the same color screws and don't see anything labeled common
In the junction box where there is 4 cables going into it. all 4 black wires connected together.. all 4 white are connected together and all 4 grounds are connected.
Old 02-11-2011, 07:42 PM   #38
I=E/R
a7ecorsair's Avatar
In your sketch of the circuit you show one cable going between switch one and switch two. Switch two has a red, black, and white wire so in the switch one box, find that cable and tell us where those same three wires are connected.
Old 02-11-2011, 08:00 PM   #39
Rewards Points: 97
[quote=a7ecorsair;589281]In your sketch of the circuit you show one cable going between switch one and switch two. Switch two has a red, black, and white wire so in the switch one box, find that cable and tell us where those same three wires are connected.[/quote
Old 02-11-2011, 08:28 PM   #40
I=E/R
a7ecorsair's Avatar
You're getting good at the sketches.
The switch one isn't wired correctly but let this sit for awhile.
Are you sure that each fixture only has one cable in the box? Something is wrong because we haven't found the power source for the light circuit.
Old 02-11-2011, 08:48 PM   #41
Rewards Points: 97
So i went and turned off the breaker to that circuit and used my tester. The one wire that goes into the house from the 4 cable junction box, powers 2 more outlets and 2 more switches inside the house or the power is run inside the house first then out to the garage..
What if i pulled the cover off the fuse panel, I'd be able to follow that cable off that specific breaker and see where it goes??
Old 02-11-2011, 09:21 PM   #42
Rewards Points: 97
Ok I followed the cable at the fuse panel. It runs into the house. I'm not sure if it goes to the outside light fixture or the outside light fixture switch. But other than that. I think I have everything mapped out right.
::EDIT:: It looks like fixture #1 is still missing power somewhere
Old 02-11-2011, 09:32 PM   #43
joed's Avatar
Is the junction box and sw1 two different boxes? According to your drawing fixture #2 has no switch controlling it. Looks like sw2 has a second cable not shown on the room map. Can you figure where it goes? The bottom right black wire looks to be the common.
Old 02-11-2011, 09:43 PM   #44
Rewards Points: 97
Junction box and sw1 are 2 different boxes. Yeah Fixture #2 just has one cable and runs to the junction box. But both switches turn on and off both fixtures. Switch 2 has only one cable that runs to switch 1
Old 02-11-2011, 10:20 PM   #45
I=E/R
a7ecorsair's Avatar
I have class all day tomorrow so good luck. I'll check in tomorrow night.
Wiring Main-Breaker Box in Detached Garage wstribl Electrical 15 05-11-2013 05:15 PM
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 11:44 AM
wiring 100A to detached garage snowman Electrical 4 11-28-2009 04:53 PM
Basement wiring question kupalino Electrical 8 11-14-2009 09:25 AM
Garage Ventilation Question eagle09tbl HVAC 5 10-22-2009 09:24 PM
