Wiring New Lights In Garage Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 12:50 PM   #1
Rewards Points: 97
Wiring new lights in garage Question
I have 2 single bulb lights in my garage. One on each side of the garage. They aren't bright so I bought new bulbs. The energy saving ones. Put them in and they both flicker when on. If I unscrew one bulb, the other bulb goes out too. I bought new lights. the 4 ft tube lights. With one wired up, it works fine. I hooked up the other one and they both flicker? Any ideas? Thanks
Tyus4 is offline   Reply With Quote
Old 02-10-2011, 01:22 PM   #2
Sounds like low voltage, Do you have a voltmeter?
Shockme is offline   Reply With Quote
Old 02-10-2011, 01:27 PM   #3
joed's Avatar
Rewards Points: 13,308
The lights are miswired. They are wired in series. That is why your old bulbs weren't bright. The fact that you unscrew one and the other goes out is what prooves this. You need to fix the wiring or call an electrician to fix it and the lights will be fine.
Old 02-10-2011, 01:29 PM   #4
Rewards Points: 97
I followed the wires because my circuit board is in my garage and its just those 2 lights and the switch on that circuit. They are hooked up to a 15 amp breaker. Don't know if that matters. And no I don't have a voltmeter. I was thinkin about maybe grabbing a new electrical switch. It looks like the houses original so it could be 60 years old. Don't know if that matters either.
Old 02-10-2011, 01:31 PM   #5
Rewards Points: 97
Would switching them from series easy enough to do? or definately electrician work?
Old 02-10-2011, 01:49 PM   #6
I=E/R
a7ecorsair's Avatar
It may be an easy fix. Since you replaced the original fixture with florescent fixtures, you should be able to tell us what you see for wiring inside each ceiling box. A picture would be helpful too.
a7ecorsair is offline   Reply With Quote
Old 02-10-2011, 02:06 PM   #7
Rewards Points: 97
There is just a black and white wire and the grounds are grounded to the metals boxes themselves in both boxes
Old 02-10-2011, 02:07 PM   #8
Rewards Points: 97
I tried a new switch....didn't do anything
Old 02-10-2011, 02:10 PM   #9
Rewards Points: 97
The way it seems to be wired is. From the electrical switch. One wire goes to one fixture and one goes to circuit board. The other fixture has one wire that goes to circuit board.
Is the 2nd fixture supposed to be tied into the electrical switch instead of circuit board?
Old 02-10-2011, 05:55 PM   #10
joed's Avatar
What is the circuit board. A light fixture doesn't have a circuit board.
If there is only one cable in each fixture then those two cables need to meet up somewhere. Where? Usually it would be the switch. How are they connected to the switch.
Old 02-10-2011, 06:50 PM   #11
We need pics, this sounds weird if they actually are in series, 60 yrs old?
Old 02-10-2011, 08:25 PM   #12
Rewards Points: 97
I didn't mean circuit board..i Meant breaker/ fuse panel
Old 02-10-2011, 08:50 PM   #13
joed's Avatar
Tell us how the lights and switch are wired.
Old 02-10-2011, 08:53 PM   #14
Rewards Points: 97
Ok I set up a ladder and traced the wires and was totally wrong. Electrical switch has one wire that goes to the fuse panel. The other goes to one fixture. Now the other fixture has one wire that runs to a junction box near the first fixture. This might be where the 2 are connected. But after that junction, the wires then run into another juction where one wire goes to a outside outlet, one goes to a outlet in the house, and one goes to a outside light. The electrical switch is a 3 way switch. I hope this helps
Old 02-10-2011, 09:05 PM   #15
Rewards Points: 97
the lights just have one black wire and one white wire and ground and the switch is a 3 way switch
Wiring Main-Breaker Box in Detached Garage wstribl Electrical 15 05-11-2013 05:15 PM
question about wiring basement with garage panel 1acman Electrical 4 01-19-2011 11:44 AM
wiring 100A to detached garage snowman Electrical 4 11-28-2009 04:53 PM
Basement wiring question kupalino Electrical 8 11-14-2009 09:25 AM
Garage Ventilation Question eagle09tbl HVAC 5 10-22-2009 09:24 PM
