Wiring In New Light - Electrical - DIY Chatroom Home Improvement Forum
Old 05-18-2008, 08:08 PM   #1
Wiring in new light
I am adding a light in my bedroom. The box that I have brought the wire into has a single pole switch in it. There are only a black and a white wire (other than the ground wire) in it that go to a wall outlet that the switch turns on and off.
I' am trying to figure out how to wire in my new light into the box. Can anyone help?
John
MrTradeshow is offline   Reply With Quote
Old 05-18-2008, 09:30 PM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
John
The switch box you ran to from the light fixture, does not have a neutral wire. It sounds like that box contains a switch leg (hot) from, and back to, the switched receptacle outlet. You need a neutral for your new light fixture. There would be a neutral wire in the receptacle outlet box.
John
jrclen is offline   Reply With Quote
Old 05-18-2008, 09:53 PM   #3
My problem is that to get to the recepticle I would have to cut through three wall studs to get to it.
There is another switch on the opposite side of the wall that may have a neutral as I know it is a three way. would I be able to tie into a neutral there?
jack
Old 05-18-2008, 10:59 PM   #4
jack
I doubt very much you will find a neutral in a three way switch. Sounds like the power and switch leg is going to the switch from the recp. What I would do is first disconnect power to the device you are working on. (at the breaker panel) Then I would disconnect the switch altogether from the recp thats both ends. Then I would fine a junction box or light box on the same circuit if possible. Run romex from the new source to your new light box..run your switch wires to the same box. Now this is were you really have to watch what you are doing. The white wire from the power source hooks to the light. The Black wire from the power source to the white wire going to the switch. The black wire from the switch to the black wire on the light. Is there any chance of you wanting a fan there as well? In that case run aa 3 wire to your switch box.
I highly recommend that you get an electrician to preform this work or at least inspect BEFORE you turn it back on.
rong1 is offline   Reply With Quote
Old 05-19-2008, 08:35 AM   #5
jrclen's Avatar
Rewards Points: 514
jack
There is a possibility you may find a neutral in the box with the three way switch. It depends how things were wired up. Pull the switch out and look for a white wire which is spliced and running through the box, not connected to the switch. Be aware, all the conductors to the new light fixture must be run together. You cannot run the hot wire to one box and the neutral to another box.
John
Help with wiring an Ikea ceiling light hlong2 Electrical 4 03-15-2008 04:22 PM
Old wiring - Bathroom Light Psully24 Electrical 11 12-01-2007 12:20 AM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 06:25 PM
wiring a light Unregistered Electrical 6 01-08-2005 09:19 PM
wiring a new light ugmr10 Electrical 2 12-30-2003 10:59 PM
