Wiring For New Dishwasher - Electrical - DIY Chatroom Home Improvement Forum
Old 05-03-2010, 09:25 PM   #1
Send a message via ICQ to vivianjacobs@ne
Wiring for new dishwasher
I am installing a new dishwasher. The old dishwasher was hardwired, while the new one needs to be plugged in to an outlet. When I went to install the outlet from the original wires, I found that there are only a black and white wire, no ground. They also seem to be on a circuit by themselves, so are not protected by a gfci.
Is it ok to install the new dishwasher to an ungrounded outlet?
vivianjacobs@ne is offline   Reply With Quote
Old 05-03-2010, 09:35 PM   #2
Is it a 3 prong plug ?
Does the Mfg instructions require any specifics ?
DW is on a dedicated circuit, disposal allowed on same circuit
Where are you located ?
Old 05-03-2010, 09:42 PM   #3
Licensed electrician
Rewards Points: 1,876
Your instructions will probably call for installation on a grounded circuit.
GFI protection not needed unless called for in instructions. Most will not.
Old 05-03-2010, 09:46 PM   #4
It is three prong. I don't see that the manufactuer specified any requirements as such. I was thinking of leaving it ungrounded and installing a gfci as the new outlet.
Thanks for your help!
Old 05-03-2010, 10:26 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
Someone correct me if I'm wrong, but you may be able to pull a ground from an existing nearby receptacle. Since the wall behind the dishwasher will be hidden anyway, you could just cut whatever you need so you could fish a wire. If you're lucky there may be a receptacle nearby.
I would still fish a full romex but just cap the other two conductor ends. Again, not sure if this is actually permitted, just an idea. I know it's not permitted to do this with a neutral even though it works, not sure what the rules are with grounds, considering they don't carry current. (normally)
Old 05-03-2010, 10:43 PM   #6
Ground must run back to the panel in the US
or grounding source - rod ?
Old 05-03-2010, 10:44 PM   #7
NEC 250.114(3) requires the use of a grounding conductor in the circuit supplying a dishwasher.
Old 05-03-2010, 10:57 PM   #8
GFCI outlet behind the DW not a good idea...reset would be a problem
Old 05-04-2010, 06:22 AM   #9
Just call me Andrew
Rewards Points: 1,020
How hard is it to run a new wire from the panel to the DW? That's the right way to do it.
Andrew
secutanudu is offline   Reply With Quote
Tags
dishwasher wiring , electrical
Dishwasher wiring question jimithing78 Electrical 6 05-11-2010 06:03 PM
Wiring a dishwasher brettadam18us Electrical 2 03-20-2010 09:19 AM
Wiring gone bad??? Dishwasher issue beginnerDIY Electrical 38 09-06-2009 07:30 AM
Exposed dishwasher wiring secutanudu Electrical 15 04-20-2009 10:44 AM
Dishwasher Wiring mcpusc Electrical 1 04-28-2008 08:19 PM
