Wiring A New Closet Light - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2011, 12:11 AM   #1
Wiring a new closet light
Just wanted to get some expert advise. I am installing a new ceiling light in a walk in closet. Currenrtly there is no fixture or wiring present. I have installed the correct box and secured it. Now is where is have some doubt.
I am hoping to use power from a switch or outlet on the outside wall. How would I properly connect to power from an exsiting switch or outlet for my new light with a switch?
Any advise would be greatly appreciated.
co-bob47 is offline   Reply With Quote
Old 06-10-2011, 12:14 AM   #2
Rewards Points: 512
First of all, you cannot put an uncovered light fixture in there (the conventional ceramic based socket and bulb type). You didn't mention what type you have, so I just wanted to give a heads up before going any further.
Can you tell us what you already have?
Old 06-10-2011, 12:35 AM   #3
Wiring new closet light
Sorry, first post on here.
I have multiple different fixtures to use, none of which are the old ceramic palte and bulb. I have a 3 light small halogne "track" fixture, and enclosed golbe ceiling mount and a pendant fixture.
Old 06-10-2011, 07:41 AM   #4
Just call me Andrew
Rewards Points: 1,020
Is the receptacle from which you propose to get power already controlled by a switch? Or is it always live? If it's live, that's your best bet.
The switch may or may not have all the wires you need to feed your new switch/light. If you'd rather feed your new stuff from the switch, you need to see how many wires are in the switch box. If the only wires in the box are the two connected to the switch, you can't use it to feed the new light. If you have the two connected to the switch plus 2 wires in the back of the box, you can use it.
The rules are very specific for closet lights. NO exposed bulbs, they must be completely enclosed. Additional rules regarding incandescent vs. fluorescent vs. LED. Basically, if your light will be closer than 12" from ANY storage space (whether you currently use it or not), it must be a Fluorescent fixture. Putting a CFL bulb in an incandescent socket does not meet this requirement. The fixture would have to be fluorescent only.
Luminaire = Fixture
Lamp = Bulb
Andrew
secutanudu is offline   Reply With Quote
Old 06-10-2011, 08:45 AM   #5
Just call me Andrew
Originally Posted by athena3 View Post
Your plan of a fluorescent fixture on the wall above the door is probably the only kind that would be allowed by code in a closet that shallow (due to separation requirements). The bulb must be covered.
In closets this shallow, it is typical to mount the light just outside the closet (to reduce the risk of fire).
Whose plan? Where do you see dimensions of the closet?
Andrew
Old 06-11-2011, 10:06 AM   #6
Licensed electrician
Rewards Points: 1,290
Just my plan
My Civil engineer did it perfectly well in my home, dimensions were decided by him!
I may be misreading this but, we don't get to make decisions like which clearance dimensions are ok. This is spelled out in the electrical codes and needs to be followed, not based on whims and wishes. It may not be perfectly well despite your thoughts.
SD515 (06-11-2011)
Old 06-11-2011, 10:40 AM   #7
Electrician
SD515's Avatar
Rewards Points: 504
It has been my experience that walk in closets are not considered shallow.
Kyle
Tags
closet , new light , outlet , switch , wiring
HELP! Wiring 2 switches with new light fixture michugana Electrical 7 04-10-2011 07:49 PM
Mercury Vapor Light Fixture Wiring Hoppy084 Electrical 4 06-25-2010 12:38 AM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 07:25 PM
wiring a new light ugmr10 Electrical 2 12-30-2003 11:59 PM
