Wiring New Circuits. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 12:31 PM   #1
Bluwolf's Avatar
Rewards Points: 87
Wiring new circuits.
This is my first post, HELP! I am installing 2 new circuits from the service panel in my M I L's basement, to the garrage. One is for a garrage door opener and an extra wall outlet. The other is for 2, switched, 48" celling lights and another wall outlet. Two questions. 1. Iwould like to run 14 gage romax tacked to the celing and stripped on both ends to pull through conduit on walls. Is this code? 2. Can I use 3/8" conduit for those wires?
Bluwolf is offline   Reply With Quote
Old 09-04-2009, 12:36 PM   #2
You can't strip the sheath off.
1/2" (trade size) the smallest conduit available. Two 14/2's will fit if it's laid out straight.
You don't need two circuits for this installation BTW.
220/221 is offline   Reply With Quote
Old 09-04-2009, 12:51 PM   #3
Bluwolf's Avatar
Rewards Points: 87
All conduit?
Thanks for the reply,220/221. I can't run romex on walls, so should I use all conduit?
Old 09-04-2009, 12:54 PM   #4
Do you have an outlet in the garage now?
Is there existing conduit in the wall that you will be using?
If not why try to put conduit in the wall - not needed?
I'd run (2) 20a circuits w/#12 wire
Old 09-04-2009, 12:58 PM   #5
You can sleeve the romex with conduit to protect it and make it look better. Just don't strip off the sheathing.
Old 09-04-2009, 01:20 PM   #6
Bluwolf's Avatar
Rewards Points: 87
Hi Scuba Dave; The one outlet in garage was feed from a ceiling pull chain light loosened and pulled down for wire access. Even I know that's not right!I was going to run conduit on wall surface for protection (per code) not in the wall. 220/221 says I don't need two circuits. The door opener might need a dedicated circuit? Thanks for your response!
Old 09-04-2009, 01:34 PM   #7
Bluwolf's Avatar
Rewards Points: 87
Sleeved romex
I forgot to add, if I sleeve the romex, I'd need 3/4" if I run 2 circuits, right? I've read that it's not code to run romex through conduit, I'm clueless. Thanks again.
AFCI and 3-wire circuits...ugghh mhops Electrical 11 03-17-2010 12:22 PM
Wiring Problems sunici Electrical 18 04-26-2009 09:27 PM
replacing old wire on existing circuits... red86yota Electrical 9 12-08-2008 07:00 PM
Wiring new detached garage/studio WShawn Electrical 4 07-21-2008 07:13 PM
