-   -   Wiring new circuits. (http://www.diychatroom.com/f18/wiring-new-circuits-52311/)
Bluwolf 09-04-2009 12:31 PM
This is my first post, HELP! I am installing 2 new circuits from the service panel in my M I L's basement, to the garrage. One is for a garrage door opener and an extra wall outlet. The other is for 2, switched, 48" celling lights and another wall outlet. Two questions. 1. Iwould like to run 14 gage romax tacked to the celing and stripped on both ends to pull through conduit on walls. Is this code? 2. Can I use 3/8" conduit for those wires?
220/221 09-04-2009 12:36 PM
You can't strip the sheath off.
1/2" (trade size) the smallest conduit available. Two 14/2's will fit if it's laid out straight.
You don't need two circuits for this installation BTW.
Bluwolf 09-04-2009 12:51 PM
All conduit?
Thanks for the reply,220/221. I can't run romex on walls, so should I use all conduit?
Scuba_Dave 09-04-2009 12:54 PM
Do you have an outlet in the garage now?
Is there existing conduit in the wall that you will be using?
If not why try to put conduit in the wall - not needed?
I'd run (2) 20a circuits w/#12 wire
220/221 09-04-2009 12:58 PM
You can sleeve the romex with conduit to protect it and make it look better. Just don't strip off the sheathing.
Bluwolf 09-04-2009 01:20 PM
Hi Scuba Dave; The one outlet in garage was feed from a ceiling pull chain light loosened and pulled down for wire access. Even I know that's not right!I was going to run conduit on wall surface for protection (per code) not in the wall. 220/221 says I don't need two circuits. The door opener might need a dedicated circuit? Thanks for your response!
Bluwolf 09-04-2009 01:34 PM
Sleeved romex
I forgot to add, if I sleeve the romex, I'd need 3/4" if I run 2 circuits, right? I've read that it's not code to run romex through conduit, I'm clueless. Thanks again.
