Wiring For New Ceiling Light - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 06:49 PM   #1
Rewards Points: 160
wiring for new ceiling light
my house was built in 1971 and all the bedrooms dont have ceiling lights. i just have lamps that i have a outlet that is connected to the switch with. i know i need to run a wire from the switch to the ceiling light but do i have to re wire that outlet too? i did a ceiling fan last year with same set up. maybe i can try and find my post on here about that but if someone has any quick input i would appreciate it. my other question was will the light be grounded at all since the 14/2 would be coming from the switch or no? if it wont be how do i ground it? thanks
jhack836 is offline   Reply With Quote
Old 01-16-2013, 09:42 PM   #2
Licensed electrician
Rewards Points: 1,258
Wiring from 71 should contain a grounding means.
You may need to rewire the receptacle, just depends on the wiring. You will need to find out what wires are available at the switch.
ceiling light problem al gilliland Electrical 0 11-15-2011 05:05 PM
Ceiling fan light kit duhtroll Electrical 10 06-21-2011 03:29 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
wiring ceiling fan to light switch cshsr Electrical 10 07-20-2009 05:08 PM
