-   -   wiring for new ceiling light (http://www.diychatroom.com/f18/wiring-new-ceiling-light-169321/)
jhack836 01-16-2013 06:49 PM
my house was built in 1971 and all the bedrooms dont have ceiling lights. i just have lamps that i have a outlet that is connected to the switch with. i know i need to run a wire from the switch to the ceiling light but do i have to re wire that outlet too? i did a ceiling fan last year with same set up. maybe i can try and find my post on here about that but if someone has any quick input i would appreciate it. my other question was will the light be grounded at all since the 14/2 would be coming from the switch or no? if it wont be how do i ground it? thanks
Jim Port 01-16-2013 09:42 PM
Wiring from 71 should contain a grounding means.
You may need to rewire the receptacle, just depends on the wiring. You will need to find out what wires are available at the switch.
