Wiring A New Air Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2013, 10:44 PM   #1
I ask the impossible!
Rewards Points: 692
Wiring a new air compressor
Two questions, just bought an 80 gallon Kobalt air compressor from Lowes, 240V rated 18.5 amps.
The instructions didn't include a wiring diagram so I wasn't certain whether I'd need a neutral or not. I wanted to get all my material in one trip, so I bought 6-3 cable figuring extra wires is better than not enough. So, I don't need neutral at the air compressor. Should I connect the wire at the circuit breaker panel or leave the neutral folded up off to the side?
I sized the breaker and wire based on a 30A circuit, I assumed that a 20 amp circuit for a device using 18.5 A might have been undersized, was I correct?
I also have a disconnect beside the on off switch at the compressor.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 04-25-2013, 10:53 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Cool ya got something to play with it.
The straight 240 volt moteur what you have there you will not need the netural at all.
Ya can cap it off on both end but see the comment below on that question.
But why end up buy 6-3 cable ?? how far is the compressour is located from the main panel ??
My reply in bleu.
Good move with disconnect switch that is my SOP with it unless you are in sight of breaker / fuse box.
Do this compressour do have thermal protection on the moteur or not ? ( that may change the way I will suggest the breaker size )
I know 20 amp breaker can hold it but normally I will sized by C.V.( HP ) and amps et voltage et distance so I know what I am dealing with it.
Merci,
Marc
Old 04-26-2013, 07:28 AM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Is this the unit?
If so, based on the specs found here the NEC requires the following;
FLA=28A
230VAC
BC conductors have to be 8/2 romex, or #10 THHN/THWN in conduit.
ITCB can be as high as 70A to allow for motor to start and run.
If the unit is not within site of the breaker panel, a disconnect will be needed. Use a non-fused knife switch which has to be horsepower rated. If a cord and plug is used it has to be horsepower rated. Which means you should hard wire the unit.
Finally, consult the manufaturers installation instructions for what they require.
Good luck!!
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 04-26-2013, 09:23 AM   #4
Rewards Points: 692
Pfft... I have no idea why I said 6-3, what I meant was that I have 10-3 NM.
I ran it inside 1/2" flex metal conduit where exposed. I bought a fused disconnect, and the air compressor is within 5 feet of the main panel. Overkill, but the way I see it I can use the hardware for when I'm remodelling the garage later.
And actually, mine is the 3 cylinder 80 gallon Kobalt compressor:
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
Little bit lower current. I was wondering if I could've gotten away with a 20 amp rated circuit, but since 20 amps would have been marginal and I recall some parts of the code about not using 100% of the current rating, and not knowing whether that section applies to this installation, I thought it would be better to go up to the next gage and breaker size.
Old 04-26-2013, 11:22 AM   #5
Rewards Points: 160
Don't know and highly doubt a 20 amp circuit would have been enough. Post the nameplate information. All of it.
Old 04-26-2013, 05:44 PM   #6
electures's Avatar
Follow the links in my signature for sizing motors. First rule. Do not use the nameplate rating. The NEC has to be used.
Old 04-26-2013, 06:35 PM   #7
Master Electrician
Rewards Points: 3,870
There you go again.
brric is online now   Reply With Quote
Old 04-26-2013, 08:31 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,938
There's a strong argument that this is not a "motor", but an "air compressor" which has certain manufacturer-specified UL-approved ratings, listed on the ratings plate.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
brric (04-26-2013)
Old 04-26-2013, 09:14 PM   #9
Rewards Points: 692
Okay... so it sounds like I need to up the conductors to #8, and up the breaker to 40A... And the disconnect is under-rated since it's 30A, so probably easiest to just not use the disconnect. Is that right?
Old 04-26-2013, 09:27 PM   #10
Master Electrician
You will be fine with 10 conductors and a 30 amp breaker.
The Following 3 Users Say Thank You to brric For This Useful Post:
Hardway (04-27-2013), k_buz (04-26-2013), mpoulton (04-27-2013)
Old 04-26-2013, 11:02 PM   #11
electures's Avatar
If that is the case then UL would have a separate standard for air compressors. Just like pool filter motors.
Edit: the UL standard for Air Compressors is UL 1450. Doesn't say anything special for motors.
Old 04-26-2013, 11:13 PM   #12
Normally I don't useally knock on your door on this one but according to the OP's specs the 4.7 CV ( HP ) is not a common number at all and for a fun part I try to plug the numbers for French codes which we do have IEC and NEMA format ( we don't use the NEMA very often but it is very handy to figures few items what the IEC don't cover ) and I read the specs sound like 2.5 CV moteur due the running current drawage which it did stated 18.5 amps @ 240 volts.
Do you have special chart for oddball moteurs ?
I did read the OP's moteur specs and good thing it did came with interal thermal overload protection.
Merci,
Marc
Old 04-29-2013, 07:42 AM   #13
electures's Avatar
Originally Posted by brric View Post
There you go again.
My recommendations are based on the unit in my link. Since it is not the same unit, obviously since the motor is different the requirements will change. Never heard of a 4.7 HP motor. I'll have to visit a Lowes and check it out.
If anybody disagrees with my calculations, please feel free to prove me wrong and back it up with relevant documentation including NEC sections.
Old 04-29-2013, 05:13 PM   #14
Master Electrician
I've done that several times in the past and you refuse to relent from your assertion that all utilization equipment with motors must be sized from
NEC tables and it justis not true.
Old 04-29-2013, 05:19 PM   #15
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
What changes this fact? I want to hear both sides of the story.
wiring heat pump and air compressor outside building lcvette Electrical 3 07-28-2011 01:32 PM
Do I really need a new compressor, or am I about to be ripped off? mrgadfly HVAC 8 07-02-2011 05:01 PM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
HVAC compressor contacts wiring???? mflores00 HVAC 1 05-28-2010 09:50 PM
Replacing Wiring From Outside Fuse Box To Central Ac Compressor bobo Electrical 8 03-02-2007 09:23 PM
