Wiring A New 12x20 Storage Shed - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-08-2013, 06:50 PM   #16
Well I joined this forum just to get some info to make sure I'm doing things right. If you don't want to share your knowledge why bother to post on this thread? Thats what forums are for on the net and I find them useful. I'm on several pc and computer forums and I like sharing my knowledge fixing computers and such. I try to share everything I know helping folks and try save them a few $$ from getting ripped off at the local PC store. Thanks to all who have helped me on this forum its greatly appreciated.
Handyworker is offline   Reply With Quote
Old 11-08-2013, 07:02 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I thought I did help. I'm just not going to give step by step instructions on how to do this job.
Old 11-08-2013, 07:03 PM   #18
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 938
I would run 8 ga wire to a small load center. The initial cost is not much more.
Never assume you won't run anything on 240 volts later. Something may come up.
Somebody offers you a 240 volt compressor or something for free, whatever....it happens.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
Handyworker (11-08-2013)
Old 11-08-2013, 07:04 PM   #19
Mad Scientist
Yeah, that's the other thing; run a larger conduit than you need, because eventually you will want more power out there.
McSteve is offline   Reply With Quote
Old 11-08-2013, 07:04 PM   #20
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,180
Originally Posted by Handyworker View Post
Ok this being said where I split them up in the shed from there can I run 14-2 for the lights and 12-2 for the outlets? Also how many outlets can I put on the 20amp circuit? Thanks for all you guys help.
Since you are using a 20 amp 2 pole breaker as the supply, all wiring must be #12.
Coastal South Carolina
Old 11-08-2013, 07:11 PM   #21
Ok I think thats what I would rather do is run like the #8 wire to a small breaker box in the shed. This is what my first plan was originally. What amp should the main shut off breaker be in the shed? Then I can get a 15 amp breaker and 14-2 wire for the lights and 2 20 amp breakers and 12-2 wire for the outlets and split them up 4 outlets per 20 amp breaker. That way if I need to add on later it will be easy.
Old 11-08-2013, 07:17 PM   #22
A "Handy Husband"
rjniles's Avatar
all I want is a couple lights and about 8 outlets and thats it. I will never use 220 so just need regular 110 outlets. I only plan to be using a maintainer for my motorcycle and maybe some regular power tools if any skill saw, jigsaw small air compressor .
From your first post, now you want a sub panel so you can add on later
Old 11-08-2013, 07:21 PM   #23
This is what I had in mind is a small breaker box to have 2-4 breakers. This is the way im used to doing things. When someone brought up the 12-3 thing I was kinda confused and used google to look it up and got 10 different answers.
Old 11-08-2013, 07:23 PM   #24
My first post ask what size wire to run from pole to main breaker then have 2 breakers 1 for lights and 1 for outlets.
Old 11-08-2013, 07:25 PM   #25
k_buz's Avatar
You will need to run 4 wires...H, H, N, G. Drive two ground rods, don't bond neutral and ground in the sub and keep the neutrals and grounds separate. Size of the feeders would be completely up to you...minimum #10's.
Old 11-09-2013, 09:22 AM   #26
If I run a small breaker box that has a main breaker and then distribute the power from there can I use these regular outlets that I already have?
Old 11-09-2013, 10:13 AM   #27
k_buz's Avatar
Not unless you install GFI breakers.
Old 11-09-2013, 10:18 AM   #28
Whats with the GFI stuff? We done my dads shop 10yrs ago. We ran like 6 or 8ga from the pole to a 100amp service panel then installed breakers from there and installed like 20 regular outlets and a ton of lights. Why cant this be done in my building? Of course I dont need the 100 amp service in my case but same setup just smaller.
Old 11-09-2013, 10:37 AM   #29
123pugsy's Avatar
Rewards Points: 938
Found this:
http://ecmweb.com/code-basics/nec-re...errupters-gfci
Handyworker (11-09-2013)
Old 11-09-2013, 10:43 AM   #30
Originally Posted by 123pugsy View Post
So this is in a non commercial 12x20 building out in the middle of nowhere 10 miles from civilization so I don't need the GFI correct?
Pugsy I tried to send you a pm but it wouldn't let me.
Wiring a shed DavidKulzer Electrical 26 03-22-2013 01:06 AM
underground wiring to tool shed Dick Dube Electrical 13 08-03-2012 07:29 PM
Wiring to shed question Burbman Electrical 26 04-06-2012 10:05 PM
Out of room..Need a storage shed!!! Gomezy3k Building & Construction 6 12-19-2011 10:27 AM
Shed Wiring Duff. Electrical 28 06-09-2009 10:06 PM
