Wiring NEMA 6-50R - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2012, 09:57 AM   #1
Wiring NEMA 6-50R
I know this is beating a dead horse but I feel like I need some clarification. I will be installing a NEMA 6-50R Receptacle for a welder in my garage and I have figured out that I will not need the neutral from reading other posts here. But do I need to ground the receptacle box? I am using a metal Raco box.
MisterSteve is offline   Reply With Quote
Old 04-29-2012, 10:01 AM   #2
are you running a new cable with an equipment grounding conductor? if so, ground the metal box the receptacle is located in.
itsnotrequired is offline   Reply With Quote
Old 04-29-2012, 10:09 AM   #3
Yes, new cable, 6/3 NM. So if the ground is connected to the receptacle, how do I go about grounding the box?
Old 04-29-2012, 10:15 AM   #4
Licensed electrician
Rewards Points: 1,608
The box should have a tapped hole for a 10-32 screw.
Old 04-29-2012, 10:21 AM   #5
Yep, I stuck a green ground screw in it. Do I then wirenut two pieces of bare #10? to the cable ground and attach one to the box and one to the receptacle?
Old 04-29-2012, 10:37 AM   #6
install a pigtail on the receptacle and a pigtail on the box ground. wirenut the two pigtails with the ground in the cable. done.
Old 04-29-2012, 10:41 AM   #7
Got it. Duh. Thanks.
Old 04-29-2012, 02:31 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Leave the ground long, wrap it around the screw, then on to the receptacle. NO need for splicing.
The Following User Says Thank You to Speedy Petey For This Useful Post:
mpoulton (04-29-2012)
Old 04-29-2012, 08:29 PM   #9
Electrical Contractor
kbsparky's Avatar
You only need a 6/2 cable for a welder outlet. The neutral wire would not be used if you installed a 6/3.
-KB
confirm wiring for 3-prong nema 10-50r plug? colarama Electrical 3 09-21-2011 10:28 PM
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 10:00 AM
Knob and Tube wiring. bronco2 Electrical 8 10-03-2009 12:36 PM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
