Wiring Multiple Porch Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 08:15 PM   #1
Rewards Points: 37
wiring multiple porch lights
Hi
is it ok to wire 120v porch lights in a series instead of parallel?
The reason i'm asking is because my 3 porch lights are currently wired in parallel. I want to install a motion sensor but i dont want to run the wires all they way back to the switch... instead i want to wire it in the middle of the series of lights.
thoughts?
thx
joshik is offline   Reply With Quote
Old 12-14-2012, 08:22 PM   #2
Licensed electrician
Rewards Points: 1,634
Series wiring is not used in houses. If the bulb went out the circuit would not work.
Old 12-14-2012, 08:27 PM   #3
Rewards Points: 37
yeh, that i dont mind bc its just porch lights and i can replace them as they break.... but would the lights get dimmer the more bulbs i add in?
thx
Old 12-14-2012, 09:31 PM   #4
joed's Avatar
Rewards Points: 12,944
The lights would get dimmer the more you added. And if you did not use all of the exact same bulbs some of them would brighter than others. There is no reason to wire lights in series. It never happens in 120 volt circuits except those old Christmas lights where one goes out and thewhole string goes dead.
Please explain in detail exactly what you are attempting to do.
Old 12-14-2012, 10:41 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,372
Originally Posted by joshik View Post
Hi
thoughts?
thx
Do you fully understand the concept of series and parrallel ?
Where will you find the 40v light bulbs ?
Cause if you want three on a 120v circuit thats what you will need !
dmxtothemax is offline   Reply With Quote
Old 12-15-2012, 07:09 AM   #6
Rewards Points: 1,514
Yes you can daisy chain the light fixtures with just one cable to feed all of them going back to the motion detector or switch.
This is actually still a parallel circuit. At each light fixture all the black wires are connected together and, in a separate bundle, all the white wires are connected together.
In a real series circuit, the white from one light fixture connects to the black of the next with just two wires in a bundle. This is never seen in 120 volt building wiring.
Wiring some new can lights Michaelpro Electrical 13 03-18-2012 10:58 PM
Wiring 6 Recessed Lights in Kitchen shawjd1 Electrical 3 01-27-2011 07:53 PM
Wiring multiple lights between power source and switch j2m Electrical 3 10-03-2010 07:29 PM
Multiple Motion Sensor Lights Tripping GFCI Wan Miguel Electrical 6 05-05-2010 11:01 AM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 12:39 PM
