Wiring Multiple Lights Between Power Source And Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 10-03-2010, 06:15 PM   #1
j2m
Wiring multiple lights between power source and switch
I did it myself under the supervision of an electrician and simply expected it to work. It hasn't. Here is what exists.
(1) panel/power source, (2) 14/2 with ground to (3) 3 way switch, (4) 14/3 with ground, (5) first light fixture, (6)14/3 with ground, (7) second light fixture, (8)14/3 with ground, (9) third light fixture, (10) 14/3 with ground, (11) 3 way switch/end.
I would like to eliminate the first switch completely (3) and control all three lights by a single pole switch at the end (11). Can anyone tell me whether this be done without re-wiring? Can anyone diagam it if it can be done?
Thanks.
j2m is offline   Reply With Quote
Old 10-03-2010, 07:24 PM   #2
joed's Avatar
Rewards Points: 12,016
It won't work with the three ways but you can make it work with the single switch.
Old 10-03-2010, 08:15 PM   #3
lets see if I can help you, You have two boxes with 3w in each one, and you have these lites that you want to be on with a sp sw. Heres the basics, You need to get the hot and switch leg somehow into one box, either by physical meads or using one of the travelers as a extension of the power or switch leg, to attach to a sp switch. By doing some simple troubleshooting you can eliminate the other swich just by using the existing wires in the wall and other boxes.
Kirky is offline   Reply With Quote
Old 10-03-2010, 08:29 PM   #4
j2m
Thanks, gentlemen. I'll give those a try.
two switches, two sets of lights one power source agsurfer Electrical 2 09-12-2010 10:23 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
Wiring diagram to move switch in box w/3 way wires and source columbuskat Electrical 4 01-30-2009 01:32 PM
