-   -   Wiring multiple lights between power source and switch (http://www.diychatroom.com/f18/wiring-multiple-lights-between-power-source-switch-82962/)
j2m 10-03-2010 06:15 PM
I did it myself under the supervision of an electrician and simply expected it to work. It hasn't. Here is what exists.
(1) panel/power source, (2) 14/2 with ground to (3) 3 way switch, (4) 14/3 with ground, (5) first light fixture, (6)14/3 with ground, (7) second light fixture, (8)14/3 with ground, (9) third light fixture, (10) 14/3 with ground, (11) 3 way switch/end.
I would like to eliminate the first switch completely (3) and control all three lights by a single pole switch at the end (11). Can anyone tell me whether this be done without re-wiring? Can anyone diagam it if it can be done?
Thanks.
joed 10-03-2010 07:24 PM
It won't work with the three ways but you can make it work with the single switch.
http://i256.photobucket.com/albums/h...ightswloop.jpg
Kirky 10-03-2010 08:15 PM
lets see if I can help you, You have two boxes with 3w in each one, and you have these lites that you want to be on with a sp sw. Heres the basics, You need to get the hot and switch leg somehow into one box, either by physical meads or using one of the travelers as a extension of the power or switch leg, to attach to a sp switch. By doing some simple troubleshooting you can eliminate the other swich just by using the existing wires in the wall and other boxes.
j2m 10-03-2010 08:29 PM
Thanks, gentlemen. I'll give those a try.
