Old 02-17-2007, 01:38 PM   #1
Wiring to multiple bathrooms question
I would like to know if code allows running 1-20 amp circuit to more than one bathroom.
I have a 1/2 bath on the main floor on one 20amp ckt (GFI outlet, light, and fan). I am finishing a basement bathroom which would have a GFI outlet, light, and fan/light. Can I run wiring from the same breaker to this new bathroom? The books I have on this topic are not clear if code allows this. Thanks.
budde97 is offline   Reply With Quote
Old 02-17-2007, 01:57 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
This depends on what code cycle your books came from. This has changed a bit over the years.
Bottom line is if the circuit is feeding just receptacles, you can share it between different baths.
If the circuit has lighting, fans, etc, then it must be isolated to just that one bathroom.
Old 02-17-2007, 01:57 PM   #3
Electrical Contractor
In todays code, the bathroom circuit can feed all bath outlets, not including lights, or it can supply everything in one bath.
The best thing to do is supply your new bath with a new 20 amp citcuit and feed lights and fans fron there.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
wiring diagram question screenporch21 Electrical 10 11-30-2008 09:14 PM
3-Way Switch Wiring Question bhpizza Electrical 4 08-07-2007 06:51 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 06:44 AM
