Wiring Multi-tap 400w 240 V Metal Halide Light To A Single Pole Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 09:19 AM   #1
wiring multi-tap 400w 240 v Metal Halide light to a single pole switch
I have a 64x 40ft shop and I am hanging three outside lights and six 400w multi-tap lights.
A electrician I know told me that I could use 240v breaker switches (120v 20a/120v 20a); single pole switches (15/20a 120/277v); regular 3-way switches (15/20a 120/277v).
The electrician said I could run a lead (12-2) from a 240v breaker and power two bays of lights (each bay will have two 240v multi-tap 400w MH). Each bay will be switched with its own 15/20a 120/277v 3-way switch, One 3-way at each end of the shop.
He also said I could run a lead (12-2) from a 240v breaker and power one bay of lights (two 240v multi-tap 400w MH) and three outside lights (one 240v multi-tap 125w MH; two 240v multi-tap 26w compact flourescents)
Is this correct code?
Being one hot wire (240v) go's to the white (non flagged) wire without being switched will this damage the ballast or light in any way?
bionicbert is offline   Reply With Quote
Old 11-08-2011, 09:44 AM   #2
Electrical Contractor
kbsparky's Avatar
A single pole switch may be used to control 240 Volt loads, but may not be considered to be the disconnecting means for such loads.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
bionicbert (11-08-2011)
help wiring exhaust fan w 2 lights AND a separate shower light into a 4 switch Taran7 Electrical 2 09-18-2014 07:07 PM
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 01:39 PM
light switch wiring question. dannat Electrical 4 05-05-2011 10:11 AM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 11:10 AM
single pole switch off of 4-way circuit itin1200 Electrical 3 10-23-2010 10:27 AM
