Wiring A Line Voltage Thermostat For Fan Forced Heaters - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2011, 11:28 AM   #1
Wiring a Line Voltage Thermostat for Fan Forced Heaters
I have a room with two electric fan heaters (Cadet), both connected to a single thermostat (old single-pole with temperature dial). The heaters are 120V. I wanted to install a programmable thermostat, so ordered the Aube TH106 programmable model. However, I'm having a hard time getting it to work!
In the junction box behind the old t-stat, there are three sets of wire. One comes in from the top of the box and seems to be the live wire. The other two come in from the bottom of the box and, I assume, feed each heater? The installation manual only showed connections for a two-wire setup, but I seem to have an extra wire. I connected the top wire to one wire on the t-stat and the other two to the other wire on the t-stat, but when I flipped the breaker on I got nothing. There is an LCD display on the new t-stat, but it remained blank. I'm not sure what to do at this point.
shumatec is offline   Reply With Quote
Old 11-09-2011, 11:38 AM   #2
Rewards Points: 1,512
How was the old thermostat wired up?
You said three sets of wires. Where did all of the individual wires go?
Can you post a picture of hte box?
Old 11-09-2011, 12:54 PM   #3
Here's a picture of the j-box (IMG_2790) and another pic (IMG_2789) showing how the old t-stat was wired. Hope that's helpful, thanks for the quick response! If it's not clear from the photo, the top wire in the box is connected to L1 and the bottom two wires are both connected to T1.
Wiring a Line Voltage Thermostat for Fan Forced Heaters-img_2789.jpg   Wiring a Line Voltage Thermostat for Fan Forced Heaters-img_2790.jpg
Old 11-10-2011, 01:35 PM   #4
Is the TH106 thermostat even compatible? It's a single pole t-stat and it seems like the old one was a double pole? Not my area of expertise, could use some help please.
Old 11-10-2011, 02:23 PM   #5
Rewards Points: 760
since it is 120V , all 3 whites goes together. the hot from top goes to one wire of tstat and the 2 black wire form heaters goes with other wire of t-stat. how many watt are the heaters?. you must be sure to not exceed capacity of t-stat. it is only 2000w at 120V
carmusic is offline   Reply With Quote
Old 11-10-2011, 02:27 PM   #6
That's how I wired it, but the panel of the t-stat was blank. None of the buttons did anything, either. However, I'm not sure about the wattage of the heaters. If each were 1500w, would that make the new t-stat not work?
Old 11-10-2011, 02:41 PM   #7
I think I'm correct in assuming they are 120V. At the panel, there is a single breaker. If the heaters were 240V, wouldn't there be two connected breakers?
Not sure how to check the wattage of the fan heaters.
Old 11-10-2011, 08:50 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,820
The last time I saw something like that, it was for a marijuana growing operation.
Remote sensor for line voltage thermostat? hbridge HVAC 7 07-06-2012 03:42 PM
Help Wiring Programmable Thermostat Brio9 HVAC 4 02-13-2011 11:25 PM
Newbie question - thermostat functioning and baseboard heaters keith-k HVAC 2 10-26-2010 09:20 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
how to wire a low voltage thermostat to a baseboard heater db3iii HVAC 4 06-05-2009 08:03 PM
