Wiring In Line Light Switch On Power Cord - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 07:53 PM   #1
Question
wiring in line light switch on power cord
the power switch for my lathe went out and i want to put an outdoor light switch in its place. there is a black, white, and green leading from the male plug and the same leading to the motor. how would i wire them with the switch? the switch has 2 terminals on one side as well as the ground.
basicbrand is offline   Reply With Quote
Old 12-07-2009, 08:01 PM   #2
Rewards Points: 1,548
Connect the two white wires (neutral) to each other only.
Connect the black wires (hot) one to each of the switch side terminals.
Connect the two green wires (ground) to each other and also run a short length of wire from the green wire junction to the green (end) terminal on the switch.
Old 12-07-2009, 08:04 PM   #3
thought so
that is what i thought but the guy at the local hardware store where i got the switch said to put both whites to one terminal, both blacks to the other terminal and the greens together. i did that and as soon as i plugged it in it popped, turned the prongs black and tripped the breaker.
Old 12-07-2009, 10:21 PM   #4
dont ever listen to a hardware guy!!!!!!!!!!!
jredwood301 is offline   Reply With Quote
Old 12-08-2009, 09:36 AM   #5
Household Handyman
Rewards Points: 1,408
You mentioned that this is a lath(e) (sp), and that it has black/white/green wires which indicates that it is 110 volts. Please make sure that your new switch is rated for the motor amperage or higher than motor amperage. Listen to Allen, not the hardware man. Allen will be here next week, the hardware man may not be there next week. Good Luck, David
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
wiring ceiling fan to light switch cshsr Electrical 10 07-20-2009 04:08 PM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Wiring a light with switch....please help!! lindo1951 Electrical 19 10-16-2006 02:32 PM
