Wiring A Lightswitch/Receptacle Socket - Old One Works - New One Doesn't? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 09:58 AM   #16
In regards to the fridge, you have an existing receptacle. You should be all set, but it is always advisable to bring it up to code. Especially in the kitchen or other wet/damp areas.
Most of the equipment grounding conductors purpose has already been covered here. It also keeps all metal surfaces at the same potential. In the case of surge protectors, they use the ground to shunt excess voltage. If you do not have a ground the excess voltage goes right into the equipment and the only thing the surge protector is good for is providing extra receptacles.
Sparky8370 is offline   Reply With Quote
Old 05-24-2010, 03:31 PM   #17
Rewards Points: 117
It worked!
Thanks for the diagram with the numbered screws.
I am an idiot, and didn't notice that the one screw was also Brass, and therefor meant for the black wire.
It works perfectly now!
LordX is offline   Reply With Quote
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
HOw to tell if a socket is propery grounded Jdrewrd Electrical 9 03-21-2009 08:10 PM
Electric wiring AMPIN88 Electrical 1 02-21-2009 10:31 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
