Wiring Lights In New Construction - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 09:22 AM   #31
If the light hugs the wall there is mostly vertical shear force on the box and so any box should do.
Even if it doesn't hug the wall and projects outward, I can't imagine a small light torqueing a box out of the wall.
The Following User Says Thank You to Yoyizit For This Useful Post:
Mi Feller (06-05-2010)
Old 06-05-2010, 09:45 AM   #32
Total outward protrusion (mounting plate and glass fixture) just over 6".
Mi Feller is offline   Reply With Quote
Old 06-05-2010, 10:04 AM   #33
Rewards Points: 204
Do not listen to the other poster. He is an engineer and knows nothing about electrical construction. Just the comment "vertical shear force on the box" should be enough for you to stay clear unless you want to turn this SIMPLE job into a science project. Sorry Yoyizit, but you are getting on my nerves.
Support a metal or plastic box securely to the framing members. I prefer metal for this application, but plastic will do just fine. While pulling the fixture up against the outside wall with the fixture screws will be tight, it may not stay tight. So mount the box at the correct depth and secure it well.
The Following User Says Thank You to J. V. For This Useful Post:
Jim Port (06-06-2010)
Old 06-05-2010, 10:37 AM   #34
Appreciate the concern. However, will use 4" metal box and secure firmly to a vertical stud with 2-3 screws. Any "pull" outward will be against quarter inch drywall. Than again, I could easily brace it underneath with a cross piece of 2x4.
Related issue: Anyone aware of anything in code preventing you from mounting a light on the wall next to interior steps (4)? Would be above level where would interfere with pedestrian traffic. Also, above an entrance door? Appreciate any thoughts.
Old 06-06-2010, 10:29 AM   #35
Rewards Points: 204
No issue at all. NEC and common sense both prevail in this post.
Old 06-06-2010, 11:21 AM   #36
Rewards Points: 1,542
It is better if the nails holding the box to the stud are at the top and bottom edges of the box as opposed to being in the middle. That is, as far apart vertically as is practical. It is better if screws are used instead of nails.
A rectangular box will hold the light better than a square box because the closer to the stud the light is, the less likely it will tilt out of the wall, box and all.
The metal strip that spans the screw holes in the front of the box should be enough to hold the light in place, if that is what comes with the light for mounting purposes.
Originally Posted by J. V. View Post
He is an engineer and knows nothing about electrical construction. Just the comment "vertical shear force on the box" .
He knows plenty about electrical construction, but he includes plenty of numbers that some folks feel they need a Ph.D. to understand.
Old 06-06-2010, 11:27 AM   #37
I'm glad to see that you have this thread under control!
Old 06-10-2010, 11:19 AM   #38
Permissible to locate porch light switch in area covered by door when open?
Understand generally not a good idea. Just wonder if NEC has a hard fast rule. Locating porch light switch on wall where door swings against would put it nearest the light and result in significant savings on wire and time. An open door would hide the switch, but not physically touch it. Thanks for thoughts.
Old 06-10-2010, 11:24 AM   #39
Not a problem
They do not really state on most placements
Around stairs is one place they do specify to some degree
As long as that light doesn't provide light for stairs you could put it in a closet
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Mi Feller (06-10-2010)
wiring lights from existing light fixture raineydr Electrical 6 03-25-2010 05:18 PM
Wiring basement lights and I'm lost qoncept Electrical 10 09-17-2009 03:50 PM
Funky wiring in Kitchen Atreyou40 Electrical 10 08-24-2009 10:05 AM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 08:35 PM
Wiring for external lights and outlets MikeinBurien Electrical 4 12-05-2005 12:16 AM
