-   -   wiring lights from existing light fixture (http://www.diychatroom.com/f18/wiring-lights-existing-light-fixture-67536/)
raineydr 03-24-2010 06:00 PM
Need to know if I can use an existing light fixture (it is powered by a light switch at the top of the basement steps) to wire 6 recess lights. If so what's the best strategy?
secutanudu 03-24-2010 06:01 PM
Do you plan to use the same switch to turn on the new recessed lights and the one at the top of the steps?
raineydr 03-24-2010 06:06 PM
If i can i would like to put those 6 recess lights on a dimmer switch. I am confused because this same existing basement light switch controls another light fixture in the basement.
secutanudu 03-24-2010 06:10 PM
Most likely you can't tap into that light to power your new lights. It is probably all switched power in the ceiling, which would mean you'd have to use the same switch. To verify, turn off the breaker and see what wires you have in the ceiling above each fixture and at the switch (how many wires and what colors are they?).
There is a chance you have a "switch loop" and that the power is fed to the fixture before the switch. In this case, you could tap into it for some new lights on their own dimmer.
raineydr 03-25-2010 09:22 AM
Thanks for the help. The set up is a switch at the bottom of the stairs and at the top of the stairs that works 2 ceiling lights. They are accessible because the basement is not finished. Just basic blue work box and light bulb.
Looking at the box for the light switch at the bottom of the stairs there is 4 white romex wires coming from it. 1 back to the electrical panel, one through the floor (I guess to the light switch at the top of the stairs, one to a smoke detector and 1 I can't make out where it goes.
The white wire from the light fixture goes acriss the floor joist and then up somehwere through the floor.
secutanudu 03-25-2010 09:43 AM
What do you have at the fixture? And try to itemize each wire (black/white).
raineydr 03-25-2010 05:18 PM
at the fixture there is a simple black/white wire setup.
