Wiring Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 10:28 PM   #1
wiring lights
Installing new light fixture, but wires in ceiling are black-white-red and new light has only black-white, so how do I wire it?
Bob
Bob1673 is offline   Reply With Quote
Old 04-23-2011, 10:30 PM   #2
Cap the red and then cap alike Colors together
jmans8666 is offline   Reply With Quote
Old 04-23-2011, 10:35 PM   #3
Wait are there 2 switches controlling the light?
Old 04-23-2011, 10:39 PM   #4
Only one switch at the wall, but ceiling fan there before that I'm replacing had separate fan and light switches (on the fan). Replacing fan with just a light.
Old 04-23-2011, 10:45 PM   #5
I would cap the red wire alone then cap alike colors together. So black to black then white to white and so on. It sounds like the red wire used to control the fan and you dont need it anymore
Old 04-23-2011, 10:47 PM   #6
So cap red and joing like colors - thanks.
Old 04-23-2011, 10:50 PM   #7
I'm also building a built-in book shelf and wiring canned lights in top shelf. My plan is to use existing outlet in wall to supply electric. Is it recommended to enclose wire up through bookshelf in conduit?
Old 04-23-2011, 10:50 PM   #8
Yeah thats what I would do and if it doesn't work than hire a pro
Old 04-23-2011, 10:52 PM   #9
For the bookshelf one I'm not so sure about code stuff like that since I'm not a pro
Old 04-23-2011, 10:55 PM   #10
ok thanks - appreciate it.
Old 04-23-2011, 10:57 PM   #11
Tell me how the light goes
Best way to route wiring for can lights? sheslostcontrol Electrical 3 01-10-2011 05:19 PM
Wiring question - two lights with one switch... Cleon26 Electrical 3 12-28-2010 10:09 AM
Wiring Basement Recessed Lights RyanNirg Electrical 1 10-14-2010 06:40 PM
Wiring lights with power coming into first light rovers1973 Electrical 2 08-23-2010 07:52 AM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 09:09 PM
