Wiring A Lighting Circut - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2011, 11:54 AM   #1
Wiring a lighting circut
Im trying to wire up a couple of lights to a switch and when the switch is on
everything seems to run fine but as soon as you turn the switch off the circuit
breaker trips. The lights are currently wired in series which i believe may be part of the problem im going to rewire for parallel but im not sure if thats why the breaker is tripping when the light is turned off. Any ideas?
ragnarbm is offline   Reply With Quote
Old 03-27-2011, 12:35 PM   #2
Just call me Andrew
Rewards Points: 1,020
Is this a 3-way switch? How many terminals are on it?
Andrew
secutanudu is offline   Reply With Quote
Old 03-27-2011, 05:17 PM   #3
joed's Avatar
Rewards Points: 13,762
Miswired switch. You are actually turning the switch ON when the breaker trips. Tell all the wire connections you made to create this circuit.
Old 03-27-2011, 06:21 PM   #4
Rewards Points: 6,652
I am going to guess the OP has a Switch leg, and messed it up, when they decided to do a weekend warrior job.
Low voltage interior wiring systems WillK Electrical 0 01-03-2011 08:14 PM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
recessed lighting WIRING tj home Electrical 29 10-31-2006 07:50 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 02:55 PM
