Wiring Light Posts Around In-Ground Pool - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 01:14 PM   #1
Wiring Light Posts around In-Ground Pool
I recently had an in-ground pool put in and want to install and wire-up 4 light posts. I will connect the metal light posts to the #8 copper bonding wire surrounding the pool. But, my question is whether I should connect the ground coming from the electrical panel to the bonding wire surrounding the pool. Is this bonding wire already connected to the ground on the electrical panel? If not, could this create a ground loop where current would flow?
slider-kmo is offline   Reply With Quote
Old 07-21-2011, 09:00 PM   #2
Lic Elect/Inspector/CPO
The metal post only have to connected to the pool bond wire if they are 5 feet or closer to the pool edge.
The pool bond wire usually connects to the pool motor, heater. It is not required to go to thepanel.
Do n ot connect the lamp grounds to the pool ponding wire.
NJMarine is offline   Reply With Quote
Old 07-21-2011, 10:29 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,858
The lamp grounds would still have to be connected to the fixtures, which are attached to the posts, which are attached to the bonding wire. So they would all end up connected anyway.
mpoulton is offline   Reply With Quote
Wiring for replacing a bathroom fan, heater, light and night light unit. tgallopbs Electrical 24 11-02-2010 10:57 AM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
Can I use recessed light wiring for a regualr light? integrity634 Electrical 1 03-18-2009 07:29 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
Replace pool light DONRILEY Electrical 5 07-20-2008 05:51 PM
