Wiring A Light Fixture With A Two Hots And Two Neutrals - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 12:51 PM   #1
wiring a light fixture with a two hots and two neutrals
Is it possible to tie the neutrals together and the grounds together without using the hots
Mike48becker is offline   Reply With Quote
Old 11-10-2010, 12:54 PM   #2
Licensed Pro
light fixture will not work without using a hot and a neutral if that is what you are asking
Old 11-10-2010, 09:15 PM   #3
Rewards Points: 1,514
Connect all the (colored) hot wires together. Connect all the (white) neutral wires together.
The white neutral wire out of a light fixture must be connected to neutral. The black hot wire out of a light fixture must be connected to hot and a white wire (such as coming from a switch) may not be used for this connection.
