-   -   wiring a light fixture with a two hots and two neutrals (http://www.diychatroom.com/f18/wiring-light-fixture-two-hots-two-neutrals-86357/)
Mike48becker 11-10-2010 12:51 PM
Is it possible to tie the neutrals together and the grounds together without using the hots
HouseHelper 11-10-2010 12:54 PM
light fixture will not work without using a hot and a neutral if that is what you are asking
AllanJ 11-10-2010 09:15 PM
Connect all the (colored) hot wires together. Connect all the (white) neutral wires together.
The white neutral wire out of a light fixture must be connected to neutral. The black hot wire out of a light fixture must be connected to hot and a white wire (such as coming from a switch) may not be used for this connection.
