Wiring A Light Fixture To An Existing Plug Receptacle Box? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 11:41 AM   #1
wiring a light fixture to an existing plug receptacle box?
I bought an under counter light fixture and I want to know if and how to wire this light fixture to an existing nearby plug receptacle box for power.
San Mike is offline   Reply With Quote
Old 09-19-2011, 11:51 AM   #2
Rewards Points: 6,652
Yes as long as you follow proper rules. What is the lighting in question that you are going to be using?
Old 09-19-2011, 12:20 PM   #3
The fixture is an under counter flourscent light fixture that I bought from Lowe's. It has wiring to either plug directly into an outlet or to hard wire it. I want to hard wire it to another plug receptacle box nearby for power if I can. What wires to what terminals on the receptacle.
Thanks, Mike
Old 09-19-2011, 12:35 PM   #4
Licensed electrician
Rewards Points: 1,864
Lighting cannot be hard wired to the small appliance branch circuits in the kitchen.
Old 09-19-2011, 12:41 PM   #5
How hard would it be for you to pull for the lighting circuit Mike, so you can hook that light up?
Old 09-19-2011, 12:43 PM   #6
I know that Jim, but I figured take it a step at a time with helping, instead of throwing it all out there. At least with my current mid-reno, I still have the option of moving circuits around, or adding on to the lighting circuit, if my wife decides to do like Mike is asking. Since we have not patched the holes that were made when installing the new work boxes for a couple of switches.
Old 09-19-2011, 12:47 PM   #7
If that is what the Op was proposing there is no reason to give someone instructions on how to install something when there are code rules against it.
Old 09-19-2011, 12:58 PM   #8
But of course Jim, you know that that never happens. How many times have you come across a situation, that a person did not follow the rules, and then you have to clean up their mess. When I redid the electric in this house, including the mirror in the bath that had lights, the wiring was taped, and not in the junction box in the top of the medicine cabinet portion of the mirror. The wiring for the garage was NM ran underground, tied into a outlet, and wired with an incorrect switch leg. There was also other various wiring nightmares for other outlets. Of course, it did not rate up there, with the 16awg zip cord used for a porch light on the trailer I used to own, and the electric water heater wired into a 15 amp circuit, but the draw was 30 amps.
Personally, I hate having to redo stuff that OP do, when they do not follow the rules.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
bathroom light fixture wiring johnl0958 Electrical 11 03-15-2011 07:40 PM
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 12:23 AM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 08:08 AM
humming sound from wiring in the ceiling to a light fixture njvcl Electrical 3 05-12-2009 10:00 AM
