Wiring Light Backwards - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2010, 01:32 PM   #1
Rewards Points: 113
Wiring light backwards
If the hot wire is wired to the white of a light fixture and the neutral is wired to the black of the light fixture, won't it still operate? Other than not to code and possibly electrocuting the next guy that works on the light, what else could it cause?
Years ago, an electrician wired one of my exhause fans backward, but he discovered the error when he turned it on.
Captflx is offline   Reply With Quote
Old 05-24-2010, 02:23 PM   #2
Master Electrician
Rewards Points: 3,678
The shell of the lamholder will be hot rather than the center contact as it should be. What did turning on the fan have to do with discovering that it was miswired? It still would work and in the same direction regardless of how it was wired unless it was a 3 phase motor.
brric is offline   Reply With Quote
Old 05-24-2010, 05:54 PM   #3
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
Isn't that enough?
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 05-27-2010, 01:24 PM   #4
Rewards Points: 113
Thanks for the post.
As I remember about the fan, I think it was discovered because it was operating but with a loud humming sound.
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 07:25 PM
Central Vac wiring...how do I get a light to go on? wease Electrical 4 02-22-2007 08:27 AM
wiring a light Unregistered Electrical 6 01-08-2005 10:19 PM
wiring a new light ugmr10 Electrical 2 12-30-2003 11:59 PM
