Wiring A Light - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 03:55 PM   #1
Wiring a Light
I am installing a light in my basement and need some help on the installation. I know that all splices have to take place inside a box however I need to attach the light to a wood beam running down the middle of the basement. I can not put a box in the wood however I can put the box above the wood and drill a hole through the beam for the wires to run in. I guess as long as the wires from my fixture are long enough to go through the hole in the beam and be spliced in the box I am ok, just need some advice on this. Attached is a pic of what I hope to do.
buildit45 is offline   Reply With Quote
Old 07-12-2012, 04:12 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Pan box screwed to the bottom of the beam. Then cut the trim around the pan box.
Old 07-12-2012, 05:32 PM   #3
joed's Avatar
Rewards Points: 12,898
Hole though the beam is not acceptable. Also box needs to be accessible. Are you planning an access door for it?
Pancake box mounted to the bottom of the beam is what you need.
Rerouting Bathroom Wiring roasted Electrical 36 05-13-2012 09:58 PM
confusion with track light stephenbishop Electrical 7 03-10-2012 01:37 PM
Wiring a ceiling light fixture jjchips Electrical 12 02-16-2012 06:42 PM
trying to figure out Knob & Tube wiring on old light fixture dalethompson Electrical 16 02-02-2012 08:42 PM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 08:08 AM
