Wiring A Lift Station - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 08:49 AM   #1
wiring a lift station
I have a lift station at my home that does not have power to it. The previous owner used to plus a cord into the small control panal to start the pump when needed. The control panal was set up to where it had a group of wires going into the ground( 1 large cable leading into the pump area then attched to the cable are 2 sets of wires 1 set black, white, green, Which to me looks like for my power in. The other 2 wires are black and white . I would think they would be control wires for the float maybe. I am a electrician but don't know much about lift stations. So I just want to bring permanent power to this thing instead of plugging a cord in all the time. Thanks Robert
shovel12 is offline   Reply With Quote
Old 11-13-2010, 10:26 AM   #2
I=E/R
a7ecorsair's Avatar
Is this a lift station from a septic to a drain field?
a7ecorsair is offline   Reply With Quote
Old 11-13-2010, 10:51 AM   #3
Rewards Points: 126
Since your an electrician this should be real easy. Get the specs and get to work.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 01:04 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
lift station hoover14 General DIY Discussions 4 04-26-2009 10:39 PM
septic lift station Cal Ponc Plumbing 6 10-07-2008 12:45 PM
