Wiring A Leviton 5374 Welder Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2012, 11:38 PM   #1
wiring a Leviton 5374 Welder Receptacle
I'm wiring a Leviton 5374 Welder Receptacle (2 pole, 3 wire, 50 Amp, 250 Volt, grounding). If I use a 3 wire with ground can i just ignore the white (neutral) wire. In other words, is it ok to wire the red and black wires as the hots (to make 220) and the green wire as ground with no nuetral?
docmurden is offline   Reply With Quote
Old 12-22-2012, 11:48 PM   #2
Idiot Emeritus
Rewards Points: 1,484
That's exactly how it's done. Cap off the white wire so it cannot touch anything else including the metal box (if the box is indeed metal....) Just twist a wirenut on the end, no need to strip the insulation off.
Rob
micromind is offline   Reply With Quote
wiring a light fixture to an existing plug receptacle box? San Mike Electrical 7 09-19-2011 12:58 PM
receptacle wiring, please help reds_21 Electrical 11 10-21-2007 07:24 PM
Wiring a 220v dryer receptacle pjpjpjpj Electrical 8 06-05-2007 04:08 PM
wiring for welder plug Bullmoose Electrical 4 12-02-2006 12:27 PM
wiring an electric receptacle Jonathan_in_KY Electrical 2 01-05-2005 09:28 AM
