Wiring Large In-Line Bathroom Fan For 2 Bathrooms? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2013, 10:47 PM   #1
Rewards Points: 186
Wiring large In-Line Bathroom fan for 2 bathrooms?
We have 2 bathrooms back to back with no exhaust fans and I'm considering getting a single large remote exhaust fan instead of 2 smaller ones. The only benefit I can see is that I can just puncture 1 hole in the roof, but I don't want to have to use a 3 way switch for both bathrooms. I'd prefer to have those "timer" switches that run the fan for a set amount of time even after you've left the room. But I'm not sure how you would accomplish this. So it would be one one circuit, feeding a single fan, with 2 switches. Does this wiring diagram work? Or am I at risk of sending power back the wrong way? I apologize for the sloppy paint picture, just wanted to get something out there. Thanks, Bill
Wiring large In-Line Bathroom fan for 2 bathrooms?-parallel-switched-fan.jpg
Ocelaris is offline   Reply With Quote
Old 03-18-2013, 10:52 PM   #2
MarginallyQualified
Rewards Points: 2,464
I wouldn't recommend it.
Joining two outlet ducts into one roof cap is as far as I'd go.
hth
Old 03-18-2013, 11:00 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'd look for something like this...
The wiring you have shown would work, but I would put a timer in each bathroom. One of the disadvantages (and advantages) of these type exhaust fans is that they are very quiet. You can think the fan is turned off because you turned the switch off and can't hear it, but it is still running. Especially if you have kids.
Old 03-18-2013, 11:01 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
hth
They are designed this way, and I install them all the time, they have a 6" exhaust. I use the Fantech brand fans.
Old 03-18-2013, 11:01 PM   #5
k_buz's Avatar
I missed the picture of the timer in your OP. If you use a timer such as the one pictured, it may require a neutral so your wiring would not work. You would need a xx/3 between the fan and each switch location.
Old 03-18-2013, 11:02 PM   #6
E2 Electrician
The only wiring critique, pull a 14-3 to each switch so you have a neutral conductor as well.
Old 03-18-2013, 11:16 PM   #7
Rewards Points: 186
Yeah, Lutron makes 2 types of their countdown timers "Maestro", one with Neutral (MA-T51MN), and one without (MA-T51). Amazon reviews say only to use the neutral switched switches with panasonic fans which is what I was looking at. Unfortunately those switches are $50 each! vs. 31$ for the hot-only switched.
My coworker has this single fan setup for 2 bathrooms in his house and likes it alot, but I'm still not sold except for the 1 roof penetration part. Otherwise it's cheaper to buy 2 separate fans and run 4" ducts and do a 6" Y fitting at the penetration with backdraft dampers.
Thanks for the quick responses
Old 03-18-2013, 11:21 PM   #8
E2 Electrician
I always shoot for a gable exit, I wont do a roof penetration, too much liability, it gets subbed out if its the only way to vent a fan.
The Following User Says Thank You to stickboy1375 For This Useful Post:
k_buz (03-18-2013)
Old 03-19-2013, 06:53 AM   #9
Rewards Points: 311
It is NEC mandatory to have the neutral in every switch box (new/ modified installations). Otherwise, you can do exactly what you wish.
al_smelter is offline   Reply With Quote
Old 03-19-2013, 07:00 AM   #10
E2 Electrician
Depends on which code cycle you are on, and, if he has access from above or below it is not required.
Old 03-19-2013, 07:00 AM   #11
k_buz's Avatar
That is only half true. Only if the OP is on the 2011 cycle and there are exceptions that make it not necessary a good percentage of the time.
Old 03-19-2013, 07:01 AM   #12
E2 Electrician
At least someone else around here has code knowledge.
k_buz (03-19-2013)
Old 03-19-2013, 09:39 AM   #13
Rewards Points: 186
So I called Lutron, and their support was very good, and very quick to get me to help. The tech said that I could not wire two of these countdown timers in parallel, but that I would have to use an Accessory switch, MA-AS with the MA-T51-MN countdown timer. He said that if you hit the accessory switch, it would do the countdown timer function... so if the master switch is set to 30 minutes, hitting the accessory switch would run the fan for 30 minutes. The Accessory switch is only $25 so that's not terrible.
Old 03-19-2013, 11:34 AM   #14
Rewards Points: 311
Since we cannot know what code cycle anyone is on, when advice is given here, it would be wise to recite the latest code requirements. You can't go wrong that way. And in the 2011 cycle, the two exceptions will not often preclude the need for the grounded circuit conductor at the switchbox.
Old 03-19-2013, 05:02 PM   #15
E2 Electrician
You can go wrong that way, you can cost someone a lot of extra aggravation, money, and time. Its just bad advice to give out incorrect advice.
wiring emergency alert to telephone line gulleyj Electrical 5 12-19-2012 08:35 AM
bathroom wiring gwilkrrs Electrical 4 11-28-2012 09:34 AM
Bathroom hot water line in my bathroom is blocked Soniafails Plumbing 2 10-14-2012 10:48 PM
bathroom wiring zephed666 Electrical 20 01-28-2011 12:56 PM
Anyone decipher this bathroom wiring? schnitz411 Electrical 8 08-08-2010 03:21 PM
