Wiring A L14-30 Receptical - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 10-28-2012, 09:24 PM   #1
wiring a L14-30 receptical
I am wanting to wire a receptical to use my generator to power my house during a power outage. my question is can i splice a L14-30 to my existing dryer cord to hook up my generator to feed power to my house considering that i won't have the dryer on and the generator plugged in at the same time? If it is possible to do this what will i need to look for to make sure i have to correct wiring and breakers?
mbax is offline
Old 10-28-2012, 09:31 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
This is a BIG no-no. That is your answer.
k_buz is offline
The Following User Says Thank You to k_buz For This Useful Post:
micromind (10-28-2012)
Old 10-28-2012, 10:53 PM   #3
Idiot Emeritus
Rewards Points: 1,492
Agree.
The only legal (and safe) way to power any panel that's connected to a utility is by making it physically impossible to have both the gen and utility connected at the same time.
Also, you'd need a 'suicide cord'. This is one that has a male plug on both ends.
It's called a 'suicide cord' for a reason......
Rob
micromind is offline
Old 10-28-2012, 11:29 PM   #4
Rewards Points: 1,192
Micheal Jackson was"musically" cool.
bobelectric is offline
Old 10-29-2012, 06:42 AM   #5
Rewards Points: 38
safest (quick) way to get power into the house is to run several heavy guage extension cords through a window or doorway. the biggest safety risk will be tripping. keep the generator away from the window or door to avoid another safety risk, CO (carbon monoxide) gas.
How large of a generator do you have? a 3k will power refrigorator, sump pump and a few lights!!! extended outages require a lot of fuel.
stay safe
bernie
bernie963 is offline
Old 10-29-2012, 10:19 AM   #6
Rewards Points: 236
You need a generator inlet and a interlock for your panel to be able to safely back feed the house.
J. V. is offline
Old 10-29-2012, 11:03 AM   #7
I don't think you guys understand what I am wanting to do. I don't want to make a suicide cord to plug into my current dryer outlet. I want to add a recepticle to the wire from the panel to the dryer. During an outage plug my generator into the recepticle, not the dryer outlet, and backfeed to my panel. I understand this will not be considered "legal"
mbax is offline
Old 10-29-2012, 11:18 AM   #8
Rewards Points: 3,130
THEN DON'T DO IT! Kill a lineman, go to prison.
md2lgyk is offline
Old 10-29-2012, 11:19 AM   #9
Electrical Contractor
kbsparky's Avatar
You can not legally do this. Either way, you can end up with exposed hot prongs on that cord/circuit.
There would be no difference whether you plugged a hot cord into the dryer outlet, or another twist-lock receptacle below it.
The proper method is to install a separate feed using a flanged inlet (not an outlet), with its own back-fed breaker and mechanical interlock kit, or transfer switch.
-KB
kbsparky is offline
Old 10-29-2012, 11:21 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Not only is it not legal it is stupid and NOT safe.
IMO threads like this should not be replied to since the OP is only going to want specific answers.
Speedy Petey is offline
The Following User Says Thank You to Speedy Petey For This Useful Post:
electures (10-29-2012)
Old 10-29-2012, 11:25 AM   #11
An old Tradesmen
Rewards Points: 8,142
That is correct, it is not legal.
beenthere is offline
The Following 2 Users Say Thank You to beenthere For This Useful Post:
electures (10-29-2012), micromind (10-29-2012)
Old 10-29-2012, 11:27 AM   #12
An old Tradesmen
Unsafe acts are not supported by this site. if you wish to find out how to do this properly, ok. But a thread on how to do it unsafely or illegally is not permitted.
This thread has been closed do to the hazardous method that is being asked about.
The Following 4 Users Say Thank You to beenthere For This Useful Post:
BigJim (10-29-2012), brric (10-29-2012), electures (10-29-2012), micromind (10-29-2012)
Closed Thread
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 10:00 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
