Wiring Into A New Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 01:00 PM   #1
Wiring into a new breaker
I have a root celler that has 2 standard 110v light sockets that have been wired and run to my fuse panel in my garage, all I need to do is wire it to a new breaker and install it into my fuse panel. This does not seem overly difficult as I believe the hard work is all done. What would be the best breaker to use and is it complicated to do this? Any help is greatly appreciated. Thank you
Shep628 is offline   Reply With Quote
Old 01-04-2012, 01:13 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Shep628 View Post
I have a root celler that has 2 standard 110v light sockets that have been wired and run to my fuse panel in my garage, all I need to do is ...
Have (the presumably qualified) whoever which did the fixture wiring come back to finish the job.
hth
Old 01-04-2012, 01:14 PM   #3
Rewards Points: 165
Use whatever brand circuit breaker that matches the brand of the service panel you have. For example, if you have a Siemens service panel then use Siemens breakers, if it's a Murray panel , then use Murray breakers. As for the wiring, if you are not installing a GFCI or AFCI breaker, then just strip the end of the hot wire, clamp it into the back of the breaker, and strip the ends off the ground and neutral wires and stick them under a screw on the ground and neutral bars on the sides of the main breaker rack. Click the breaker into place and turn it on.
chronojosh is offline   Reply With Quote
Old 01-04-2012, 02:33 PM   #4
Licensed electrician
Rewards Points: 1,892
The neutral and ground cannot be used under the same screw in the panel.
Old 01-04-2012, 02:37 PM   #5
Not a Noob or Boob
I don't think he meant on the same screw. Ground to ground bar and Common to the common bar.
Originally Posted by chronojosh View Post
...and stick them under a screw on the ground and neutral bars on the sides of the main breaker rack
Rob1975 is offline   Reply With Quote
Old 01-04-2012, 03:20 PM   #6
That was just to clarify or if someone did not know better.
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Tripped breaker after wiring a new dimmer, ok to use dimmer after correcting mistake? toobhed Electrical 7 09-20-2011 08:24 AM
double breaker wiring palmerg31 Electrical 11 09-13-2011 09:36 PM
Breaker box wiring question(s) janralix Electrical 6 08-29-2010 10:13 PM
