#1 |
Wiring Interference Question
Finishing a room in my basement, and there will be several types of wall stud wiring and junction outlet going on, including:
- AC - Cable Coax - RCA analog audio - Cat6 Ethernet - Audio Optical - USB - Speaker wire - HDMI My general goal is to keep AC lines at least 2 inches away from all other wires at all times (most of the time 1 ft away). Other than that, though, I'm not sure what to expect or mitigate ahead of time as far as interference issues. Any ideas or general guidelines? (i.e., its ok to couple cat6, optical, usb, hdmi together, however keep AC, coax, speaker, RCA at least X inches away from each other and everything else) Thanks for any advice... |
#2 |
Special User
Well you don't need to worry about the optical, it's immune to RFI/EMI and generates none of it's own. Run it wherever.
If you haven't purchased your patch cables yet, get ones that have a big lump between the ends. That's a magnetic toroid, which helps filter out interference. You can cross 120VAC with digital data cables (USB, Cat6, HDMI) at right angles. It's just parallel runs that cause problems. Digital data should all play nice with each other even in close proximity, but all will inject noise into speakers and RCA cables to some degree. Speaker wire could conceivably induce noise in RCA too, dunno if it's significant. The coax cable I'd put off by itself. It's susceptible to RFI and generates RFI of it's own. Use the good RG6 instead of crappy RG59. |
#3 |
JOATMON
Tyler pretty much coverd the bases.....
However....I would rethink your USB. That is not really intended for long runs. Noise is not your issue.......you might want to rethink running USB in walls. I believe the spec for USB 2.0 is a max of 5m....or about 15'.
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
Thanks for the quick feedback.
What you say all makes sense. Can you quantify "off by itself", a little, specifically with regards to the RCA, speaker, and coax that might cause trouble with other cables? The studs are 3.5" wide, so about 2" is the max I can separate them out in some cases as they pass each other. Can I do something to further shield the proximity in brief places where the pass closely? Regarding USB, noted and understood. I had the spare cable, key stones and junction outlet spots. It was just to possibly USB connect a computer directly to a TV 15 ft away (through the wall), but no real specific planned use. I was just going to lay the wire. If I find a use and it works, great. If not, no biggie. |
#5 |
Reading up a little more on this USB 2.0 distance limitation, apparently it is 16 ft (5m). If the total USB distance between the computer and TV is <= 16ft, including:
- USB cable from comp to keystone 1 - USB cable though wall from keystone 1 to keystone 2 - USB cable from keystone 2 to TV + -------------------------------------- <= 16 ft Will this likely work? Or am I just wasting my time with this USB endeavor, of which I am not sure I am even going to use. Thanks... |
#6 |
I've never done this before, but you might try using a USB repeater, like is described here, to get the length required.
#7 | ||
Special User
Wiring Interference QuestionQuote:
As for coax, the cable just by itself usually isn't too "leaky", in fact you can buy Cat6+Coax bundled together. It's the connectors where the noise (both spewed out and injected) is the worst, so use high-quality terminations and take care when installing them. Use threaded coax patch cables, not the push-on type. You might consider having two wall plates placed in the left and right of a stud bay (typically 16" on center): one for digital, one for audio. That would give you over 10" of separation. |
#8 |
JOATMON
Use a good shielded RCA cable and you will be fine.
As for speakers....in reality, the speaker wire is more likely to cause interference in other wiring vs other stuff affecting the speakers. Your driving those with a low impeadance source...they will not be an issue......(translation, you don't need to waste money on Monster cables)
#9 |
The AC line is most likely to affect the speakers, those are the two I'd want to keep as far apart and as non-parallel as possible.
Maybe enclose the AC in metallic conduit? Last edited by Dave632; 11-15-2012 at 11:02 AM. Reason: added: metallic |
#10 |
Average Joe/ex-Navy IC3
Forget optical, it is a dead technology. For HDMI, pull Cat-6, rca audio and video use rg-6. In reality, all you need where the tv is going, is just one hdmi interface, everything else would connect to the AV receiver.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#11 |
IF you have newer equipment. Cables are cheaper than tvs an receivers if you don't. But plan for the new stuff now while you're feeding the old.
#12 | |
If it is going inside a stand that the tv will be sitting on, everything will be in the cabinet under the tv, with the speakers next to it, and only wiring that would need to be run, is surround speaker wiring, ethernet, coax for satellite or catv. To the OP, you really need to look at the room designs at AVSforum.com to see what people have done, and what a really good home theater setup is like, not something just thrown together. Wiring it up is not hard, it is just that if you do not have a written plan and schematic where everything is going, you are going to find and run into trouble during the middle of your install.
| Display Modes | |
| 208V/3 Phase Wiring Question | efalcon1 | Electrical | 12 | 09-28-2012 12:22 PM |
| Outdoor Wiring Question | OKDrew63 | Electrical | 30 | 08-15-2012 12:25 AM |
| Adding 2 outlets in the middle of a series of outlets - wiring question | Evan55 | Electrical | 7 | 06-14-2012 10:43 AM |
| Attic wiring question | everyman | Electrical | 4 | 07-07-2009 10:47 AM |
| Trane Heat Pump tstat replacement with Honeywell prog - wiring question | sep23 | HVAC | 2 | 10-20-2006 10:10 PM |
