Wiring Indoor Timer To Outdoor Sprinkler Valve - Electrical - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 12:50 PM   #1
Wiring indoor timer to outdoor sprinkler valve
I am using 18 gauge wiring for connection. Do I need to run the wiring from valve to entrance wall in conduit?
Or can I run wiring from sprinkler valve to rubber grommet in outdoor wall?
tomie
tomie is offline   Reply With Quote
Old 02-21-2012, 08:41 PM   #2
Julius793's Avatar
tomie
You can run it however you like it's low-voltage, however it's a good idea with the conduit so it doesn't get cut.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Mixer valve to transfer valve installation CarlV Plumbing 0 09-13-2011 11:28 AM
Fix-a-loo TOILET outlet valve not closing/shutting toiletproblem Plumbing 4 08-21-2011 03:25 AM
Converting Robertshaw Gas Valve 7100 DER-S7C mikefrommi HVAC 9 03-08-2011 12:46 PM
honeywell transformer and zone valve wiring rocksaranac1 HVAC 1 11-02-2010 07:36 PM
Sprinkler control wiring re-connect (diagram) ScottR Plumbing 4 06-25-2009 08:51 PM
