Old 03-01-2008, 03:11 PM   #1
Wiring humidifier to furnace
Installing a whole house humidifier on my furnace. A question on wiring the hot between fan control and furnace blower. Where to tie in to the new transformer?
Fitter is offline   Reply With Quote
Old 03-01-2008, 03:26 PM   #2
Electrician
Whats your question? Just make sure the humidifier only turns on when the fan is running on a call for heat.
chris75 is offline   Reply With Quote
Old 03-01-2008, 03:36 PM   #3
Didn't get to write in my question before sent post.
From my diagram where do I tie into the L1 (hot) between the fan control and the furnace motor (to 24v transformer).scan0001.pdf
Old 03-01-2008, 04:35 PM   #4
Electrician
From my diagram where do I tie into the L1 (hot) between the fan control and the furnace motor (to 24v transformer).Attachment 2696
what does the humidifier directions tell you to do? and what exactly are you trying to tie into the L1? A relay? what brand/model did you buy?
okay I get it, your trying to have a transformer energized only on a call for heat to run the humidifier correct?
Old 03-01-2008, 04:40 PM   #5
Yes , when heat/blower come on it'll tell the transformer to open the selanoid valve to allow water to the humidifier. Honeywell H8908B humidistat. Honeywell HE220A humidifier.
Old 03-01-2008, 06:15 PM   #6
Electrician
Is your furnace two speeds?
On multispeed blower applications, do not wire
the high voltage side of the transformer to the
same power source that services the furnace
blower. Premature transformer burnout can
occur.
I have the same unit BTW, but I have the automatic humidistat.
Old 03-01-2008, 06:24 PM   #7
Electrician
Most furnaces have a large enough transformer already installed, I would just come off of the "W" and "C" terminal to feed your humidistat then your humidifier.
Need Luxaire Forced Air Furnace Wiring Diagram misticvillage HVAC 7 04-15-2009 05:09 AM
Furnace drum humidifier question justin76 HVAC 1 02-17-2008 09:45 PM
Installing a Furnace Humidifier pieman312 HVAC 1 01-08-2008 10:58 PM
Putting a new Motor in a Carrier Furnace... Wiring issues cbrent HVAC 3 10-08-2007 07:08 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
