Old 11-16-2008, 03:52 PM   #1
Wiring in Hot Tub
Can anyone help me find a diagram for wiring in a hot tub to a 220 breaker?
remodeler1 is offline   Reply With Quote
Old 11-16-2008, 04:10 PM   #2
Electrician
Wiring in Hot Tub
What about the rest of the project? wire size, codes on wiring a tub, required disconnect means, wiring methods, etc.
chris75 is offline   Reply With Quote
Old 11-16-2008, 04:10 PM   #3
Wiring in Hot Tub
It's a four wire feed to a disconnect or spa panel, then a four wire feed to the tub(Or a three wire if it's a 240V only tub). If you don't know this then you really shouldn't be wiring a hot tub.
jerryh3 is offline   Reply With Quote
Old 11-16-2008, 04:28 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Wiring in Hot Tub
That's right inside the control box cover or in the instructions.
It's the rest of the job that's important and the is NO "diagram" for that.
PLEASE hire a pro. This is no place to mess around if you don't know what you are doing!
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 33 03-18-2009 08:11 PM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 04:56 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
