Old 01-31-2013, 04:06 PM   #1
Wiring a Hot Tub
Hello,
Looking to wire a hot tub in Ontario, and wondering the easiest way to code. I moved into a house with an existing hot tub, with a disconnect inside the house approx. 20m away. However the cable is indoor rated in not in conduit.
I'm fairly good with household wiring, and confident I can tackle this, however I just want to confirm code for this to ensure it is safe and to code;
1. Bury cable in conduit 18" subsurface
2. Provide GFCI disconnect outside (approx. ? distance from tub)
3. Provide secondary GFCI outlet on pedestal with disconnect
Is there anything else I need to think or worry about?
Thanks!
ldogg is offline   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
