Wiring Help Three Wire To Two Wire Install - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2009, 10:21 AM   #1
Post
Wiring help three wire to two wire install
Hello Im removing a ceiling fan which is wired to three wires red,black, white and groung but replacing with a standard two wire light fixture black and white wires. Which wires do i use to be able to control from the existing light switch.
israelsoto99 is offline   Reply With Quote
Old 06-28-2009, 11:24 AM   #2
Rewards Points: 82
Either the red and white or the black and white, plus the ground, you choose. Put a wirenut on the unused wire and tuck it into the ceiling box. When wiring the fixture make sure the socket shell is the neutral. (grounded conductor). It's the threaded part (shell) of the light bulb socket.
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 03:37 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 08:04 AM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
exhaust fan wiring question (aluminum wire) sflamedic Electrical 6 01-14-2008 05:41 PM
